- To:
- Subject: Re: [cgal-discuss] Anonymous SVN access Jet fitting
- Date: Wed, 14 Oct 2009 11:49:02 +0200
Puzzling!
can you try a real planar plane and a simple smooth surface (parabolic cylinder or elliptic paraboloid there is a picture in the manual 53.2) to see if the results are as expected and hence check there is not pb in the interface?
Marc
On 14 , Oct , 2009, at 11:06 , Thorben Kröger wrote:
On Wednesday 14 October 2009 07:52:02 Marc Pouget wrote:
One thing is surprising on this picture:
all the vertices on a "line" of the mesh should have the same
computed differential quantities, cause the mesh is regular and the
patches symmetric, so the estimations are only done on translates. So
i think there may be a bug in the way neighbors are retrieved, you
may want to check and compare the patches for vertices along the same
"line". Note that if this is the problem, it is only related to the
example code and not the core of the package.
I have modified my plane example to output the values computed for another
point translated in x-direction along the plane, it should receive the same
normal vector.
in plane_01.png, I have added the point to the right (it's located where the
arrow originate) and it's neighors, again painted in blue '*'. The top view
plane_03.png shows that the neighborhood is not completely the same, but
close. I would have thought that using such a large neighborhood would be
robust to such slight changes?
The side view is plane_02.png, the two red vectors are the ones estimated by
CGAL for the two neighborhoods.
Any thoughts?
Cheers,
Thorben
https://lists-sop.inria.fr/wws/info/cgal- discuss<plane_03.png><plane_02.png><plane_01.png>
- [cgal-discuss] Anonymous SVN access, Thorben Kröger, 10/13/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Marc Pouget, 10/13/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Thorben Kröger, 10/13/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Marc Pouget, 10/14/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Thorben Kröger, 10/14/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Marc Pouget, 10/15/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Thorben Kröger, 10/19/2009
