- To:
- Cc: Björn Andres <>
- Subject: Re: [cgal-discuss] Anonymous SVN access Jet fitting
- Date: Wed, 14 Oct 2009 09:06:48 +0000
On Wednesday 14 October 2009 07:52:02 Marc Pouget wrote:
> One thing is surprising on this picture:
> all the vertices on a "line" of the mesh should have the same
> computed differential quantities, cause the mesh is regular and the
> patches symmetric, so the estimations are only done on translates. So
> i think there may be a bug in the way neighbors are retrieved, you
> may want to check and compare the patches for vertices along the same
> "line". Note that if this is the problem, it is only related to the
> example code and not the core of the package.
I have modified my plane example to output the values computed for another
point translated in x-direction along the plane, it should receive the same
normal vector.
in plane_01.png, I have added the point to the right (it's located where the
arrow originate) and it's neighors, again painted in blue '*'. The top view
plane_03.png shows that the neighborhood is not completely the same, but
close. I would have thought that using such a large neighborhood would be
robust to such slight changes?
The side view is plane_02.png, the two red vectors are the ones estimated by
CGAL for the two neighborhoods.
Any thoughts?
Cheers,
Thorben
Description: PNG image
- [cgal-discuss] Anonymous SVN access, Thorben Kröger, 10/13/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Marc Pouget, 10/13/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Thorben Kröger, 10/13/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Marc Pouget, 10/14/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Thorben Kröger, 10/14/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Marc Pouget, 10/15/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Thorben Kröger, 10/19/2009
