- To:
- Subject: Re: [cgal-discuss] Anonymous SVN access Jet fitting
- Date: Wed, 14 Oct 2009 09:52:02 +0200
One thing is surprising on this picture:
all the vertices on a "line" of the mesh should have the same computed differential quantities, cause the mesh is regular and the patches symmetric, so the estimations are only done on translates. So i think there may be a bug in the way neighbors are retrieved, you may want to check and compare the patches for vertices along the same "line". Note that if this is the problem, it is only related to the example code and not the core of the package.
best
Marc
On 13 , Oct , 2009, at 18:20 , Thorben Kröger wrote:
<normals_4rings.png>
- [cgal-discuss] Anonymous SVN access, Thorben Kröger, 10/13/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Marc Pouget, 10/13/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Thorben Kröger, 10/13/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Marc Pouget, 10/14/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Thorben Kröger, 10/14/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Marc Pouget, 10/15/2009
- Re: [cgal-discuss] Anonymous SVN access Jet fitting, Thorben Kröger, 10/19/2009
