cgal-discuss - Re: [cgal-discuss] Anonymous SVN access Jet fitting
  • To:
  • Subject: Re: [cgal-discuss] Anonymous SVN access Jet fitting
  • Date: Thu, 15 Oct 2009 13:20:47 +0200
ok, then if you send me the data for the puzzling plane example, I may try to dig this out. I have no more clue so far.
Best
Marc
On 14 , Oct , 2009, at 12:08 , Thorben Kröger wrote:
On Wednesday 14 October 2009 09:49:02 Marc Pouget wrote:
Puzzling!
can you try a real planar plane
Attached smooth_plane.png calls the same matlab interface function that I used
in my previous experiments. That looks very much OK.
and a simple smooth surface
(parabolic cylinder or elliptic paraboloid there is a picture in the
manual 53.2)
Attached file smooth_ellipsoid.png This looks ok as well.
to see if the results are as expected and hence check
there is not pb in the interface?
Cheers,
Thorben
https://lists-sop.inria.fr/wws/info/cgal- discuss<smooth_plane.png><smooth_ellipsoid.png>
