cgal-discuss - Re: [cgal-discuss] problem with CGAL instalation
  • To:
  • Subject: Re: [cgal-discuss] problem with CGAL instalation
  • Date: Tue, 20 Oct 2009 11:19:24 +0200
Arun, the explanation is in the message you quoted yourself:
On Tuesday 20 October 2009 11:04:38 pratihast22089 wrote:
> CMake Error at cmake/modules/FindQt4.cmake:783 (MESSAGE):
> It appears you're trying to use Visual Studio with Qt built by mingw
If you want to use Qt4 with Visual Studio 9, you need to recompile Qt
yourself
from sources. You seem to have installed Qt3 precompiled binaries for the
MinGW compiler. Apparently the CMake macro FindQt4.cmake throws a fatal error
if it detects that bad combination of (Qt binaries)+compiler.
Laurent Rineau, PhD
