- To:
- Subject: Re: [cgal-discuss] problem with CGAL instalation
- Date: Wed, 21 Oct 2009 02:32:07 -0700 (PDT)
Hi,
I installed the CGAL3.5.
I am trying to run the simple program.
when i build the solution it build successfully but whn i am trying to run
the program , its not running ,
It gives some message like this:
This aaplication has failed to start because gmp-vc90-mt-gd.dll was not
found. Re-installing the application may fix this problem.
Please help me .
my program code is :
#include "stdafx.h"
#include <iostream>
#include <CGAL/convex_hull_2.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef K::Point_2 Point_2;
int main()
Point_2 points[5] = { Point_2(0,0), Point_2(10,0), Point_2(10,10),
Point_2(6,5), Point_2(4,1) };
Point_2 result[5];
Point_2 *ptr = CGAL::convex_hull_2( points, points+5, result );
std::cout << ptr - result << " points on the convex hull" << std::endl;
return 0;
Regrads,
Arun K. Pratihast
ITC
pratihast22089 wrote:
> hi ,
> I am the beginner.
> I am trying to insatlling CGAL3.4 for windows using the instruction
> given in the URL:
> http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows
> When i configure using cmake-gui . , i got the following error and
> warning:
> CGAL_MAJOR_VERSION=3
> CGAL_MINOR_VERSION=4
> CGAL_BUILD_VERSION=
> CGAL_SONAME_VERSION=3
> CGAL_SOVERSION =3.0.0
> CGAL_REFERENCE_CACHE_DIR=
> Building static libraries
> CMake Warning (dev) at CMakeLists.txt:88 (include):
> Policy CMP0011 is not set: Included scripts do automatic cmake_policy
> PUSH
> and POP. Run "cmake --help-policy CMP0011" for policy details. Use the
> cmake_policy command to set the policy and suppress this warning.
> The included script
> C:/CGAL/CGAL-3.4/cmake/modules/CGAL_Common.cmake
> affects policy settings. CMake is implying the NO_POLICY_SCOPE option
> for
> compatibility, so the effects are applied to the including context.
> This warning is for project developers. Use -Wno-dev to suppress it.
> Targetting Visual Studio 9 2008
> Target build enviroment supports auto-linking
> Using VC90 compiler.
> Generator uses intermediate configuration directory: $(OutDir)
> USING CMake version: 2.6.4
> System: Windows
> Build type: Debug
> USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR
> -D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE
> -D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /D_DEBUG /MDd /Zi /Ob0
> /Od /RTC1'
> USING LDFLAGS = ' '
> GMP include: C:/CGAL/CGAL-3.4/auxiliary/gmp/include
> GMP libraries:
> GMP definitions:
> USING GMP_VERSION = '4.2.4'
> MPFR include: C:/CGAL/CGAL-3.4/auxiliary/gmp/include
> MPFR libraries:
> MPFR definitions:
> USING MPFR_VERSION = '2.3.2'
> Boost include: C:/boost/boost_1_38
> Boost libraries:
> optimized;C:/boost/boost_1_38/lib/libboost_thread-vc90-mt-1_38.lib;debug;C:/boost/boost_1_38/lib/libboost_thread-vc90-mt-gd-1_38.lib
> Boost definitions:
> USING BOOST_VERSION = '1.38.0'
> CMAKE_INSTALL_PREFIX=C:/Program Files/CGAL
> Could NOT find ZLIB (missing: ZLIB_LIBRARY ZLIB_INCLUDE_DIR)
> OpenGL include:
> OpenGL libraries: glu32;opengl32
> NOTICE: CGAL_ImageIO needs ZLib to read compressed files. That feature
> will not be activated.
> CGAL_Qt3 needs Qt3, cannot be configured.
> CMake Error at cmake/modules/FindQt4.cmake:783 (MESSAGE):
> It appears you're trying to use Visual Studio with Qt built by mingw
> Call Stack (most recent call first):
> src/CGALQt4/CMakeLists.txt:18 (find_package)
> Configuring incomplete, errors occurred!
> Please help me to Solve this problem.
> Kind Regrads,
> Arun Kr. Pratihast
> ITC
View this message in context:
http://www.nabble.com/problem-with-CGAL-instalation-tp25971260p25989239.html
- [cgal-discuss] problem with CGAL instalation, pratihast22089, 10/20/2009
- Re: [cgal-discuss] problem with CGAL instalation, Laurent Rineau (GeometryFactory), 10/20/2009
- Re: [cgal-discuss] problem with CGAL instalation, Monique Teillaud, 10/20/2009
- Re: [cgal-discuss] problem with CGAL instalation, pratihast22089, 10/20/2009
- Re: [cgal-discuss] problem with CGAL instalation, pratihast22089, 10/21/2009
- Re: [cgal-discuss] problem with CGAL instalation, Laurent Rineau (GeometryFactory), 10/21/2009
