cgal-discuss - Re: [cgal-discuss] problem with CGAL instalation
  • To:
  • Subject: Re: [cgal-discuss] problem with CGAL instalation
  • Date: Tue, 20 Oct 2009 14:33:56 +0200
On Tuesday 20 October 2009 13:40:47 pratihast22089 wrote:
> Hi,
> Thank you for the responce.
> I re-instaled the cgal3.5 and complie the qt in visual studio2008 by using
> qmake command.
> After that when i configure CGAL using cmake-gui . i got the following
> errror :
> CMake Error at C:/Program Files/CMake
> 2.6/share/cmake-2.6/Modules/CPack.cmake:686 (message):
> CPack package description file: "C:/CGAL/CGAL-3.5/README" could not be
> found.
> Call Stack (most recent call first):
> C:/Program Files/CMake 2.6/share/cmake-2.6/Modules/CPack.cmake:690
> (cpack_check_file_exists)
> CMakeLists.txt:565 (INCLUDE)
> Regards,
> Arun K. Pratihast
> ITC
> Configuring incomplete, errors occurred!
> > hi ,
> > I am the beginner.
> > I am trying to insatlling CGAL3.4 for windows using the instruction
> > given in the URL:
> > http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-
> >on-windows
> > When i configure using cmake-gui . , i got the following error and
> > warning:
> > CGAL_MAJOR_VERSION=3
> > CGAL_MINOR_VERSION=4
> > CGAL_BUILD_VERSION=
> > CGAL_SONAME_VERSION=3
> > CGAL_SOVERSION =3.0.0
> > CGAL_REFERENCE_CACHE_DIR=
> > Building static libraries
> > CMake Warning (dev) at CMakeLists.txt:88 (include):
> > Policy CMP0011 is not set: Included scripts do automatic cmake_policy
> > PUSH
> > and POP. Run "cmake --help-policy CMP0011" for policy details. Use
> > the cmake_policy command to set the policy and suppress this warning.
> > The included script
> > C:/CGAL/CGAL-3.4/cmake/modules/CGAL_Common.cmake
> > affects policy settings. CMake is implying the NO_POLICY_SCOPE option
> > for
> > compatibility, so the effects are applied to the including context.
> > This warning is for project developers. Use -Wno-dev to suppress it.
> > Targetting Visual Studio 9 2008
> > Target build enviroment supports auto-linking
> > Using VC90 compiler.
> > Generator uses intermediate configuration directory: $(OutDir)
> > USING CMake version: 2.6.4
> > System: Windows
> > Build type: Debug
> > USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR
> > -D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE
> > -D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /D_DEBUG /MDd /Zi
> > /Ob0 /Od /RTC1'
> > USING LDFLAGS = ' '
> > GMP include: C:/CGAL/CGAL-3.4/auxiliary/gmp/include
> > GMP libraries:
> > GMP definitions:
> > USING GMP_VERSION = '4.2.4'
> > MPFR include: C:/CGAL/CGAL-3.4/auxiliary/gmp/include
> > MPFR libraries:
> > MPFR definitions:
> > USING MPFR_VERSION = '2.3.2'
> > Boost include: C:/boost/boost_1_38
> > Boost libraries:
> > optimized;C:/boost/boost_1_38/lib/libboost_thread-vc90-mt-1_38.lib;debug;
> >C:/boost/boost_1_38/lib/libboost_thread-vc90-mt-gd-1_38.lib Boost
> > definitions:
> > USING BOOST_VERSION = '1.38.0'
> > CMAKE_INSTALL_PREFIX=C:/Program Files/CGAL
> > Could NOT find ZLIB (missing: ZLIB_LIBRARY ZLIB_INCLUDE_DIR)
> > OpenGL include:
> > OpenGL libraries: glu32;opengl32
> > NOTICE: CGAL_ImageIO needs ZLib to read compressed files. That feature
> > will not be activated.
> > CGAL_Qt3 needs Qt3, cannot be configured.
> > CMake Error at cmake/modules/FindQt4.cmake:783 (MESSAGE):
> > It appears you're trying to use Visual Studio with Qt built by mingw
> > src/CGALQt4/CMakeLists.txt:18 (find_package)
Strange. You should uncheck the option WITH_CPACK in cmake-gui. Have you
checked it manually?
Laurent Rineau, PhD
