- To:
- Subject: Re: [cgal-discuss] problem with CGAL instalation
- Date: Tue, 20 Oct 2009 11:24:52 +0200
Laurent Rineau (GeometryFactory) wrote:
Arun, the explanation is in the message you quoted yourself:
On Tuesday 20 October 2009 11:04:38 pratihast22089 wrote:
CMake Error at cmake/modules/FindQt4.cmake:783 (MESSAGE):
It appears you're trying to use Visual Studio with Qt built by mingw
If you want to use Qt4 with Visual Studio 9, you need to recompile Qt yourself from sources. You seem to have installed Qt3 precompiled binaries for the MinGW compiler. Apparently the CMake macro FindQt4.cmake throws a fatal error if it detects that bad combination of (Qt binaries)+compiler.
Hi
Let me add that it would be better to install the current version of CGAL, which is 3.5.
best,
Monique Teillaud
- [cgal-discuss] problem with CGAL instalation, pratihast22089, 10/20/2009
- Re: [cgal-discuss] problem with CGAL instalation, Laurent Rineau (GeometryFactory), 10/20/2009
- Re: [cgal-discuss] problem with CGAL instalation, Monique Teillaud, 10/20/2009
- Re: [cgal-discuss] problem with CGAL instalation, pratihast22089, 10/20/2009
- Re: [cgal-discuss] problem with CGAL instalation, pratihast22089, 10/21/2009
- Re: [cgal-discuss] problem with CGAL instalation, Laurent Rineau (GeometryFactory), 10/21/2009
