- To:
- Subject: Re: [cgal-discuss] problem with CGAL instalation
- Date: Wed, 21 Oct 2009 12:02:11 +0200
On Wednesday 21 October 2009 11:32:07 pratihast22089 wrote:
> Hi,
> I installed the CGAL3.5.
> I am trying to run the simple program.
> when i build the solution it build successfully but whn i am trying to run
> the program , its not running ,
> It gives some message like this:
> This aaplication has failed to start because gmp-vc90-mt-gd.dll was not
> found. Re-installing the application may fix this problem.
> Please help me .
When you use DLLs, you need them to be found at runtime. You can add to the
environment variable PATH the path to the directory that contains gmp-vc90-mt-
gd.dll, or copy that dll in the directory where your executable is. if you
distribute your program to somebody else, you will need to distribute gmp-
vc90-mt-gd.dll as well (and you have the right to do so, under the terms of
the GNU LGPL license).
Laurent Rineau, PhD
- [cgal-discuss] problem with CGAL instalation, pratihast22089, 10/20/2009
- Re: [cgal-discuss] problem with CGAL instalation, Laurent Rineau (GeometryFactory), 10/20/2009
- Re: [cgal-discuss] problem with CGAL instalation, Monique Teillaud, 10/20/2009
- Re: [cgal-discuss] problem with CGAL instalation, pratihast22089, 10/20/2009
- Re: [cgal-discuss] problem with CGAL instalation, pratihast22089, 10/21/2009
- Re: [cgal-discuss] problem with CGAL instalation, Laurent Rineau (GeometryFactory), 10/21/2009
