Thanks for the prompt reply. I made new project with the MFC DLL and
chose the " " but I still have same
errors. I couldn't find "MT DLL code generation" where can I find it.
BTW I am using Visual Studio 9 and windows 64.
Thank you,
Tina
On Thu, Dec 10, 2009 at 1:20 PM, Pierre
Alliez <>
wrote:
hi Tina,
actually - I am having the same problem with GMP and visual.
choose the option: MFC in a shared lib and MT DLL code generation - not
static.
Thank you for your reply. I tried with the cmake too but still same
errors. I even addressed all the lib files in my code individually and
still have same error. I am guessing the problem is not finding
library. maybe I am missing some of the lib file. I have following
files :
Thanks Laurent, how should I do that? I
guess that should
be problem but when I checked my c++ directory , it was already in lib
and include file, it is also in the windows environment "path" too. is
there somewhere else that I need to check.
1>Linking...
1>cloud_points.obj : error LNK2019: unresolved external symbol
__imp____gmpq_clear referenced in function "public: __thiscall
CGAL::Gmpq_rep::~Gmpq_rep(void)" (??1Gmpq_rep@CGAL@@QAE@XZ)
__imp____gmpq_set_d referenced in function "public: __thiscall
CGAL::Gmpq::Gmpq(double)" (??0Gmpq@CGAL@@QAE@N@Z)
__imp____gmpq_init referenced in function "public: __thiscall
CGAL::Gmpq_rep::Gmpq_rep(void)" (??0Gmpq_rep@CGAL@@QAE@XZ)
__imp____gmpq_mul referenced in function "public: class CGAL::Gmpq
& __thiscall CGAL::Gmpq::operator*=(class CGAL::Gmpq const &)"
(??XGmpq@CGAL@@QAEAAV01@ABV01@@Z)
__imp____gmpq_cmp_si referenced in function "bool __cdecl
CGAL::operator==(class CGAL::Gmpq const &,int)"
(??8CGAL@@YA_NABVGmpq@0@H@Z)
__imp__mpfr_clear referenced in function "public: struct
std::pair<double,double> __thiscall
CGAL::Real_embeddable_traits<class
CGAL::Gmpq>::To_interval::operator()(class CGAL::Gmpq const
&)const "
(??RTo_interval@?$Real_embeddable_traits@VGmpq@CGAL@@@CGAL@@QBE?AU?$pair@NN@std@@ABVGmpq@2@@Z)
__imp__mpfr_get_d referenced in function "public: struct
&)const "
__imp__mpfr_set_q referenced in function "public: struct
&)const "
__imp__mpfr_init2 referenced in function "public: struct
&)const "
__imp____gmpq_add referenced in function "public: class CGAL::Gmpq
& __thiscall CGAL::Gmpq::operator+=(class CGAL::Gmpq const &)"
(??YGmpq@CGAL@@QAEAAV01@ABV01@@Z)
__imp____gmpq_sub referenced in function "public: class CGAL::Gmpq
& __thiscall CGAL::Gmpq::operator-=(class CGAL::Gmpq const &)"
(??ZGmpq@CGAL@@QAEAAV01@ABV01@@Z)
__imp____gmpq_set_si referenced in function "public: __thiscall
CGAL::Gmpq::Gmpq(int)" (??0Gmpq@CGAL@@QAE@H@Z)
__imp____gmpq_div referenced in function "public: class CGAL::Gmpq
& __thiscall CGAL::Gmpq::operator/=(class CGAL::Gmpq const &)"
(??_0Gmpq@CGAL@@QAEAAV01@ABV01@@Z)
__imp____gmpq_cmp referenced in function "bool __cdecl
CGAL::operator<(class CGAL::Gmpq const &,class CGAL::Gmpq const
&)" (??MCGAL@@YA_NABVGmpq@0@0@Z)
__imp____gmpq_equal referenced in function "bool __cdecl
CGAL::operator==(class CGAL::Gmpq const &,class CGAL::Gmpq const
&)" (??8CGAL@@YA_NABVGmpq@0@0@Z)
__imp____gmpq_set referenced in function ___gmpq_neg
1>F:\fingerprint\codes\cloud_points\Debug\cloud_points.exe : fatal
error LNK1120: 16 unresolved externals
do you have any suggestion to fix this. I appreciate your help.
Thanks,
Tina
Ce courrier électronique et toutes les pièces éventuellement jointes qu’il contient sont CONFIDENTIELS et destinés exclusivement à l’usage de leur destinataire. Si une erreur de transmission ou une adresse erronée a mal dirigée ce courrier, merci d’en informer l’expéditeur en lui faisant une réponse par courrier électronique dès réception. Si vous n’êtes pas le destinataire de ce courrier, vous ne devez pas l’utiliser, le conserver, en faire état, le distribuer, le copier, l’imprimer ou en révéler le contenu à une tierce partie.
Ce courrier électronique est à usage strictement informatif et ne saurait engager de quelque manière que ce soit INFOTERRA France SAS, ni ses filiales.
This e-mail and any attachments hereto are CONFIDENTIAL and intended solely for the use of the addressee. If you have received this e-mail in error please send it back to the person that sent it to you.
If you have received it in error, please notify the sender by return email. If you are not the addressee of this email, you must not use, keep, disseminate, copy, print or otherwise deal with it.
This email is for information only and will not bind INFOTERRA France SAS in any contract or obligation, nor its subsidiaries.
