- To:
- Subject: Re: [cgal-discuss] linker error in cgal example
- Date: Fri, 11 Dec 2009 17:44:50 +0100
On Friday 11 December 2009 17:35:47 tina rumi wrote:
> Hi Laurent,
> Thanks for the tips. I recompile it with both CMake-generated and my
> project. Warning is gone but error is still there. I attached the new log.
Do you compile in 64 bits mode of 32 bits? What version (64/32 bits) of
GMP/MPFR is installed in C:\CGAL\CGAL-3.5\auxiliary\gmp\lib ? Maybe you are
trying to mix architectures.
Laurent Rineau, PhD
- Re: [cgal-discuss] linker error in cgal example, (continued)
- Re: [cgal-discuss] linker error in cgal example, Laurent Saboret, 12/10/2009
- Re: [cgal-discuss] linker error in cgal example, tina rumi, 12/10/2009
- Re: [cgal-discuss] linker error in cgal example, Pierre Alliez, 12/10/2009
- Re: [cgal-discuss] linker error in cgal example, Laurent Rineau (GeometryFactory), 12/11/2009
- Re: [cgal-discuss] linker error in cgal example, tina rumi, 12/11/2009
- Re: [cgal-discuss] linker error in cgal example, Laurent Saboret, 12/11/2009
- Re: [cgal-discuss] linker error in cgal example, Laurent Rineau (GeometryFactory), 12/14/2009
- Re: [cgal-discuss] linker error in cgal example, tina rumi, 12/14/2009
- Re: [cgal-discuss] linker error in cgal example, tina rumi, 12/15/2009
