cgal-discuss - Re: [cgal-discuss] linker error in cgal example
  • To:
  • Subject: Re: [cgal-discuss] linker error in cgal example
  • Date: Mon, 14 Dec 2009 16:12:52 -0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=m9W1veiHI1ERdC9wsN30Zl/Xn+hFOWb+OyX+KUn0Ez4QDNLhKvERtSNxIQiwuMnghU 2KOmNtabPtHPhZ8Egn8/F3z2/BDRTtrUgSoto0hsGdlOG8L+sR0XFU/maz64SjH8knqS pUomqSXw+C/FCed2gY+ButtYvB2GgkvNT0NCs=
Thank you for the reply! I did both way : Cmake created project and myself. both have same problem.
I have 64-bit machine. Can it be the problem? I try many things.  I ran out of the idea.
Thank you,
Tina
On Mon, Dec 14, 2009 at 3:59 PM, Laurent Rineau (GeometryFactory) <> wrote:
Le vendredi 11 décembre 2009 18:13:05, tina rumi a écrit :
> Actually, in VC++ I just used the default mode which is Debug and Win32 .
> I am using GMP/MPFR that are installed with CGAL, I didn't change anything.
> So I am guessing it is 32 bit. The only thing is I am using Windows XP 64
> for the plat form but other stuff should be 32, since I did't change them.
I am sorry, I do not have any clue.
How have you create the Visual C++ project? CMake? Made by yourself?
Laurent Rineau, PhD
Release Manager of the CGAL Project       http://www.cgal.org/
R&D
Engineer at GeometryFactory           http://www.geometryfactory.com/
