cgal-discuss - Re: [cgal-discuss] linker error in cgal example
  • To:
  • Subject: Re: [cgal-discuss] linker error in cgal example
  • Date: Mon, 14 Dec 2009 19:35:07 -0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=JFVr8s0SAK2zURiywbBHNfmfUKSwgnPpXIP01evM9Hjnj6hkqN+3735pSqwSC28q5g piL8Nni1xZ6kBKcFpw9Ipe9zhRkVAQfgNHRcxMzleogsjCRQGXzwRhlF2SCm/tNjB/h1 v6MAtTt60pTzX/0LN2GtQVftWIvkc6WYh8QAQ=
Wow! finally I got it work. Thanks Laurent for all the help. the problem was I should choose 32-bit platform when I am installing cgal, although I am using 64-platform.
Thanks,
Tina
On Mon, Dec 14, 2009 at 5:11 PM, Laurent Rineau (GeometryFactory) <> wrote:
Le lundi 14 décembre 2009 22:12:52, tina rumi a écrit :
> Thank you for the reply! I did both way : Cmake created project and myself.
> both have same problem.
> I have 64-bit machine. Can it be the problem? I try many things.  I ran out
> of the idea.
You should try to remove the directory "C:\CGAL\CGAL-3.5\auxiliary\", and to
reinstall CGAL. And be careful when you choose the flavour of gmp/mpfr you
install.
Laurent Rineau, PhD
Release Manager of the CGAL Project       http://www.cgal.org/
R&D
Engineer at GeometryFactory           http://www.geometryfactory.com/
