cgal-discuss - Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example
  • To:
  • Subject: Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example
  • Date: Tue, 29 Jun 2010 15:12:07 +0200
  • Organization: INFOTERRA
Hi Xie Yi,
Which version of TAUCS are you using (look in CGAL-README.TXT)?
Laurent S.
Xie Yi wrote:
Hi, Laurent,
I've done "sudo make install" after "make". And the most files you suggested
I should look for are there except the blaswrap.h.
Regards
XIE, Yi
Laurent Saboret-2 wrote:
Xie Yi wrote:
Thank you for your answer, Laurent.
Here is what I get after I removed CMakeCache.txt.
rm CMakeCache.txt
cmake -DCGAL_DIR=/home/abbotxie/Programs/CGAL-3.6 .
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Build type: Release
-- USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG'
-- USING EXEFLAGS = ' '
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- Looking for sgemm_
-- Looking for sgemm_ - not found
-- Looking for sgemm - not found
-- A library with BLAS API not found. Please specify library location.
-- LAPACK requires BLAS.
-- TAUCS requires LAPACK and BLAS.
-- NOTICE: Some of the executables in this directory need the TAUCS
library
and will not be compiled.
-- Configuring done
-- Generating done
-- Build files have been written to:
/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3
Here is what I get with make in Taucs folder:
abbotxie@abbotxie-laptop:~/Programs/taucs_full$ make
mkdir obj
mkdir: cannot create directory `obj': File exists
make: [obj/linux/exists.log] Error 1 (ignored)
mkdir obj/linux/
echo exists > obj/linux/exists.log
cc -c -O3 -Wall -std=c99   -DMACHTYPE_ -I src/ -I build/linux/ -I
external/src/   \
          progs/taucs_blas_underscore_test.c \
          -o ./obj/linux/taucs_blas_underscore_test.o
cc  \
          -o ./obj/linux/taucs_blas_underscore_test \
          obj/linux/taucs_blas_underscore_test.o -L external/lib/linux
-llapack -L external/lib/linux -lf77blas -lcblas -latlas -L
external/lib/linux -lmetis -lg2c -lm
obj/linux/taucs_blas_underscore_test build/linux/taucs_config_tests.h
Linking with dgemm_ succedded
external/src/   \
          progs/taucs_blas_nounderscore_test.c \
          -o ./obj/linux/taucs_blas_nounderscore_test.o
cc  \
          -o ./obj/linux/taucs_blas_nounderscore_test \
          obj/linux/taucs_blas_nounderscore_test.o -L external/lib/linux
obj/linux/taucs_blas_nounderscore_test.o: In function `main':
taucs_blas_nounderscore_test.c:(.text+0xa4): undefined reference to
`dgemm'
collect2: ld returned 1 exit status
make: [build/linux/taucs_config_tests.h] Error 1 (ignored)
obj/linux/taucs_blas_nounderscore_test build/linux/taucs_config_tests.h
make: obj/linux/taucs_blas_nounderscore_test: Command not found
make: [build/linux/taucs_config_tests.h] Error 127 (ignored)
external/src/   \
          progs/taucs_c99_complex_test.c \
          -o ./obj/linux/taucs_c99_complex_test.o
cc  \
          -o ./obj/linux/taucs_c99_complex_test \
          obj/linux/taucs_c99_complex_test.o -L external/lib/linux
-llapack
-L external/lib/linux -lf77blas -lcblas -latlas -L external/lib/linux
-lmetis -lg2c -lm
obj/linux/taucs_c99_complex_test build/linux/taucs_config_tests.h
C99 complex numbers seem to be supported, 1+sqrt(-1)=-1.000000+1.000000i
external/src/   \
          progs/taucs_cilk_test.c \
          -o ./obj/linux/taucs_cilk_test.o
progs/taucs_cilk_test.c:8:19: error: cilk.h: No such file or directory
progs/taucs_cilk_test.c:10: warning: ignoring #pragma lang
progs/taucs_cilk_test.c:12: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
‘__attribute__’ before ‘int’
progs/taucs_cilk_test.c:17: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
cc  \
          -o ./obj/linux/taucs_cilk_test \
          obj/linux/taucs_cilk_test.o -L external/lib/linux -llapack -L
-lmetis
-lg2c -lm
cc: obj/linux/taucs_cilk_test.o: No such file or directory
obj/linux/taucs_cilk_test build/linux/taucs_config_tests.h
make: obj/linux/taucs_cilk_test: Command not found
mkdir bin
mkdir: cannot create directory `bin': File exists
make: [bin/linux/exists.log] Error 1 (ignored)
mkdir bin/linux/
echo exists > bin/linux/exists.log
mkdir lib
mkdir: cannot create directory `lib': File exists
make: [lib/linux/exists.log] Error 1 (ignored)
mkdir lib/linux/
echo exists > lib/linux/exists.log
external/src/   \
        -DTAUCS_CORE_GENERAL \
        src/taucs_sn_llt.c \
        -o ./obj/linux/taucs_sn_llt.o
src/taucs_sn_llt.c:1339: warning: ‘tree_first_descendant’ defined but not
used
external/src/   \
        -DTAUCS_CORE_DOUBLE \
        -o ./obj/linux/taucs_sn_llt_D.o
external/src/   \
        -DTAUCS_CORE_SINGLE \
        -o ./obj/linux/taucs_sn_llt_S.o
external/src/   \
        -DTAUCS_CORE_DCOMPLEX \
        -o ./obj/linux/taucs_sn_llt_Z.o
external/src/   \
        -DTAUCS_CORE_SCOMPLEX \
        -o ./obj/linux/taucs_sn_llt_C.o
external/src/   \
        src/taucs_linsolve.c \
        -o ./obj/linux/taucs_linsolve.o
external/src/   \
        src/taucs_logging.c \
        -o ./obj/linux/taucs_logging.o
external/src/   \
        src/taucs_memory.c \
        -o ./obj/linux/taucs_memory.o
external/src/   \
        src/taucs_timer.c \
        -o ./obj/linux/taucs_timer.o
external/src/   \
        src/taucs_ccs_base.c \
        -o ./obj/linux/taucs_ccs_base.o
external/src/   \
        -o ./obj/linux/taucs_ccs_base_D.o
external/src/   \
        -o ./obj/linux/taucs_ccs_base_S.o
external/src/   \
        -o ./obj/linux/taucs_ccs_base_Z.o
external/src/   \
        -o ./obj/linux/taucs_ccs_base_C.o
external/src/   \
        src/taucs_vec_base.c \
        -o ./obj/linux/taucs_vec_base.o
external/src/   \
        -o ./obj/linux/taucs_vec_base_D.o
external/src/   \
        -o ./obj/linux/taucs_vec_base_S.o
external/src/   \
        -o ./obj/linux/taucs_vec_base_Z.o
external/src/   \
        -o ./obj/linux/taucs_vec_base_C.o
external/src/   \
        src/taucs_ccs_ops.c \
        -o ./obj/linux/taucs_ccs_ops.o
external/src/   \
        -o ./obj/linux/taucs_ccs_ops_D.o
external/src/   \
        -o ./obj/linux/taucs_ccs_ops_S.o
external/src/   \
        -o ./obj/linux/taucs_ccs_ops_Z.o
external/src/   \
        -o ./obj/linux/taucs_ccs_ops_C.o
external/src/   \
        src/taucs_ccs_io.c \
        -o ./obj/linux/taucs_ccs_io.o
external/src/   \
        -o ./obj/linux/taucs_ccs_io_D.o
src/taucs_ccs_io.c: In function ‘taucs_dccs_read_ccs’:
src/taucs_ccs_io.c:884: warning: ignoring return value of ‘fscanf’,
declared
with attribute warn_unused_result
src/taucs_ccs_io.c:888: warning: ignoring return value of ‘fscanf’,
declared
src/taucs_ccs_io.c:895: warning: ignoring return value of ‘fscanf’,
declared
src/taucs_ccs_io.c:899: warning: ignoring return value of ‘fscanf’,
declared
external/src/   \
        -o ./obj/linux/taucs_ccs_io_S.o
src/taucs_ccs_io.c: In function ‘taucs_sccs_read_ccs’:
declared
declared
declared
src/taucs_ccs_io.c:904: warning: ignoring return value of ‘fscanf’,
declared
external/src/   \
        -o ./obj/linux/taucs_ccs_io_Z.o
src/taucs_ccs_io.c: In function ‘taucs_zccs_read_ccs’:
declared
declared
declared
src/taucs_ccs_io.c:911: warning: ignoring return value of ‘fscanf’,
declared
external/src/   \
        -o ./obj/linux/taucs_ccs_io_C.o
src/taucs_ccs_io.c: In function ‘taucs_cccs_read_ccs’:
declared
declared
declared
src/taucs_ccs_io.c:920: warning: ignoring return value of ‘fscanf’,
declared
external/src/   \
        src/taucs_ccs_order.c \
        -o ./obj/linux/taucs_ccs_order.o
external/src/   \
        src/taucs_ccs_factor_llt.c \
        -o ./obj/linux/taucs_ccs_factor_llt.o
external/src/   \
        -o ./obj/linux/taucs_ccs_factor_llt_D.o
external/src/   \
        -o ./obj/linux/taucs_ccs_factor_llt_S.o
external/src/   \
        -o ./obj/linux/taucs_ccs_factor_llt_Z.o
external/src/   \
        -o ./obj/linux/taucs_ccs_factor_llt_C.o
external/src/   \
        src/taucs_ccs_solve_llt.c \
        -o ./obj/linux/taucs_ccs_solve_llt.o
external/src/   \
        -o ./obj/linux/taucs_ccs_solve_llt_D.o
external/src/   \
        -o ./obj/linux/taucs_ccs_solve_llt_S.o
external/src/   \
        -o ./obj/linux/taucs_ccs_solve_llt_Z.o
external/src/   \
        -o ./obj/linux/taucs_ccs_solve_llt_C.o
external/src/   \
        src/taucs_complex.c \
        -o ./obj/linux/taucs_complex.o
external/src/   \
        -o ./obj/linux/taucs_complex_D.o
external/src/   \
        -o ./obj/linux/taucs_complex_S.o
external/src/   \
        -o ./obj/linux/taucs_complex_Z.o
external/src/   \
        -o ./obj/linux/taucs_complex_C.o
external/src/   \
        src/taucs_ccs_ooc_llt.c \
        -o ./obj/linux/taucs_ccs_ooc_llt.o
external/src/   \
        -o ./obj/linux/taucs_ccs_ooc_llt_D.o
src/taucs_ccs_ooc_llt.c:1096: warning: ‘recursive_read_L’ defined but not
used
src/taucs_ccs_ooc_llt.c:1161: warning:
‘recursive_leftlooking_supernodal_factor_llt_ooc’ defined but not used
src/taucs_ccs_ooc_llt.c:1308: warning:
‘recursive_compute_supernodes_in_core_old’ defined but not used
src/taucs_ccs_ooc_llt.c:1338: warning:
‘recursive_compute_supernodes_ipostorder’ defined but not used
external/src/   \
        -o ./obj/linux/taucs_ccs_ooc_llt_S.o
used
external/src/   \
        -o ./obj/linux/taucs_ccs_ooc_llt_Z.o
used
external/src/   \
        -o ./obj/linux/taucs_ccs_ooc_llt_C.o
used
external/src/   \
        src/taucs_ccs_ooc_lu.c \
        -o ./obj/linux/taucs_ccs_ooc_lu.o
external/src/   \
        -o ./obj/linux/taucs_ccs_ooc_lu_D.o
external/src/   \
        -o ./obj/linux/taucs_ccs_ooc_lu_S.o
external/src/   \
        -o ./obj/linux/taucs_ccs_ooc_lu_Z.o
external/src/   \
        -o ./obj/linux/taucs_ccs_ooc_lu_C.o
external/src/   \
        src/taucs_ooc_io.c \
        -o ./obj/linux/taucs_ooc_io.o
external/src/   \
        src/taucs_iter.c \
        -o ./obj/linux/taucs_iter_D.o
external/src/   \
        src/taucs_vaidya.c \
        -o ./obj/linux/taucs_vaidya_D.o
src/taucs_vaidya.c:336: warning: ‘quick_sort’ defined but not used
src/taucs_vaidya.c: In function ‘amst_preconditioner_create’:
src/taucs_vaidya.c:3667: warning: ‘dilation’ may be used uninitialized in
this function
src/taucs_vaidya.c:3667: note: ‘dilation’ was declared here
src/taucs_vaidya.c: In function ‘taucs_amwb_preconditioner_create’:
src/taucs_vaidya.c:214: warning: ‘h.edges’ may be used uninitialized in
this
function
src/taucs_vaidya.c:1376: note: ‘h.edges’ was declared here
src/taucs_vaidya.c:215: warning: ‘h.key’ may be used uninitialized in
this
function
src/taucs_vaidya.c:1376: note: ‘h.key’ was declared here
external/src/   \
        src/taucs_recvaidya.c \
        -o ./obj/linux/taucs_recvaidya_D.o
src/taucs_recvaidya.c: In function
‘taucs_recursive_amwb_preconditioner_create’:
src/taucs_recvaidya.c:254: warning: ‘p’ may be used uninitialized in this
function
external/src/   \
        src/taucs_gremban.c \
        -o ./obj/linux/taucs_gremban_D.o
external/src/   \
        src/taucs_ccs_xxt.c \
        -o ./obj/linux/taucs_ccs_xxt_D.o
external/src/   \
        src/taucs_ccs_generators.c \
        -o ./obj/linux/taucs_ccs_generators_D.o
src/taucs_ccs_generators.c: In function ‘taucs_ccs_generate_rrn’:
src/taucs_ccs_generators.c:446: warning: suggest parentheses around
comparison in operand of ‘!=’
external/src/   \
        src/taucs_malloc.c \
        -o ./obj/linux/taucs_malloc.o
g77 -c -O3 -g -fno-second-underscore -Wall \
        external/src/readhb.f \
        -o ./obj/linux/readhb.o
        external/src/amdatr.f \
        -o ./obj/linux/amdatr.o
external/src/amdatr.f: In subroutine `amdatr':
In file included from external/src/amdatr.f:0:
external/src/amdatr.f:404: warning: unused variable 'dext'
external/src/amdatr.f:406: warning: 'me' might be used uninitialized in
this
function
        external/src/amdbar.f \
        -o ./obj/linux/amdbar.o
external/src/amdbar.f: In subroutine `amdbar':
In file included from external/src/amdbar.f:0:
external/src/amdbar.f:405: warning: unused variable 'dext'
external/src/amdbar.f:407: warning: 'me' might be used uninitialized in
this
function
        external/src/amdexa.f \
        -o ./obj/linux/amdexa.o
external/src/amdexa.f: In subroutine `amdexa':
In file included from external/src/amdexa.f:0:
external/src/amdexa.f:396: warning: unused variable 'wnvi'
external/src/amdexa.f:396: warning: unused variable 'we'
external/src/amdexa.f:393: warning: unused variable 'dext'
external/src/amdexa.f:395: warning: 'me' might be used uninitialized in
this
function
        external/src/amdhaf.f \
        -o ./obj/linux/amdhaf.o
external/src/amdhaf.f: In subroutine `amdhaf':
In file included from external/src/amdhaf.f:0:
external/src/amdhaf.f:403: warning: unused variable 'wnvi'
external/src/amdhaf.f:403: warning: unused variable 'we'
external/src/amdhaf.f:400: warning: unused variable 'dext'
external/src/amdhaf.f:402: warning: 'me' might be used uninitialized in
this
function
        external/src/amdhat.f \
        -o ./obj/linux/amdhat.o
external/src/amdhat.f: In subroutine `amdhat':
In file included from external/src/amdhat.f:0:
external/src/amdhat.f:402: warning: unused variable 'wnvi'
external/src/amdhat.f:402: warning: unused variable 'we'
external/src/amdhat.f:399: warning: unused variable 'dext'
external/src/amdhat.f:401: warning: 'me' might be used uninitialized in
this
function
        external/src/amdpre.f \
        -o ./obj/linux/amdpre.o
external/src/amdpre.f: In subroutine `amdpre':
In file included from external/src/amdpre.f:0:
external/src/amdpre.f:120: warning: 'ntemp' might be used uninitialized
in
this function
        external/src/amdtru.f \
        -o ./obj/linux/amdtru.o
external/src/amdtru.f: In subroutine `amdtru':
In file included from external/src/amdtru.f:0:
external/src/amdtru.f:396: warning: unused variable 'wnvi'
external/src/amdtru.f:396: warning: unused variable 'we'
external/src/amdtru.f:393: warning: unused variable 'dext'
external/src/amdtru.f:395: warning: 'me' might be used uninitialized in
this
function
        external/src/genmmd.f \
        -o ./obj/linux/genmmd.o
external/src/   \
         external/src/colamd.c \
        -o ./obj/linux/colamd.o
rm -rf lib/linux/libtaucs.a
ar cr lib/linux/libtaucs.a obj/linux/taucs_sn_llt.o
obj/linux/taucs_sn_llt_D.o obj/linux/taucs_sn_llt_S.o
obj/linux/taucs_sn_llt_Z.o obj/linux/taucs_sn_llt_C.o
obj/linux/taucs_linsolve.o obj/linux/taucs_logging.o
obj/linux/taucs_memory.o obj/linux/taucs_timer.o
obj/linux/taucs_ccs_base_D.o obj/linux/taucs_ccs_base_S.o
obj/linux/taucs_ccs_base_Z.o obj/linux/taucs_ccs_base_C.o
obj/linux/taucs_vec_base.o obj/linux/taucs_vec_base_D.o
obj/linux/taucs_vec_base_S.o obj/linux/taucs_vec_base_Z.o
obj/linux/taucs_vec_base_C.o obj/linux/taucs_ccs_ops.o
obj/linux/taucs_ccs_ops_D.o obj/linux/taucs_ccs_ops_S.o
obj/linux/taucs_ccs_ops_Z.o obj/linux/taucs_ccs_ops_C.o
obj/linux/taucs_ccs_io.o obj/linux/taucs_ccs_io_D.o
obj/linux/taucs_ccs_io_S.o obj/linux/taucs_ccs_io_Z.o
obj/linux/taucs_ccs_io_C.o obj/linux/taucs_ccs_order.o
obj/linux/taucs_ccs_factor_llt.o obj/linux/taucs_ccs_factor_llt_D.o
obj/linux/taucs_ccs_factor_llt_S.o obj/linux/taucs_ccs_factor_llt_Z.o
obj/linux/taucs_ccs_factor_llt_C.o obj/linux/taucs_ccs_solve_llt.o
obj/linux/taucs_ccs_solve_llt_D.o obj/linux/taucs_ccs_solve_llt_S.o
obj/linux/taucs_ccs_solve_llt_Z.o obj/linux/taucs_ccs_solve_llt_C.o
obj/linux/taucs_complex.o obj/linux/taucs_complex_D.o
obj/linux/taucs_complex_S.o obj/linux/taucs_complex_Z.o
obj/linux/taucs_complex_C.o obj/linux/taucs_ccs_ooc_llt.o
obj/linux/taucs_ccs_ooc_llt_D.o obj/linux/taucs_ccs_ooc_llt_S.o
obj/linux/taucs_ccs_ooc_llt_Z.o obj/linux/taucs_ccs_ooc_llt_C.o
obj/linux/taucs_ccs_ooc_lu.o obj/linux/taucs_ccs_ooc_lu_D.o
obj/linux/taucs_ccs_ooc_lu_S.o obj/linux/taucs_ccs_ooc_lu_Z.o
obj/linux/taucs_ccs_ooc_lu_C.o obj/linux/taucs_ooc_io.o
obj/linux/taucs_iter_D.o obj/linux/taucs_vaidya_D.o
obj/linux/taucs_recvaidya_D.o obj/linux/taucs_gremban_D.o
obj/linux/taucs_ccs_xxt_D.o obj/linux/taucs_ccs_generators_D.o
obj/linux/taucs_malloc.o obj/linux/readhb.o obj/linux/amdatr.o
obj/linux/amdbar.o obj/linux/amdexa.o obj/linux/amdhaf.o
obj/linux/amdhat.o
obj/linux/amdpre.o obj/linux/amdtru.o obj/linux/genmmd.o
obj/linux/colamd.o
ranlib lib/linux/libtaucs.a
external/src/   \
         progs/direct.c \
        -o ./obj/linux/direct.o
progs/direct.c: In function ‘actual_main’:
progs/direct.c:402: warning: ignoring return value of ‘fscanf’, declared
progs/direct.c:406: warning: ignoring return value of ‘fscanf’, declared
cc  \
        -o ./bin/linux/direct \
        obj/linux/direct.o \
        -Llib/linux/ -ltaucs \
        -L external/lib/linux -llapack -L external/lib/linux -lf77blas
-lcblas -latlas -L external/lib/linux -lmetis -lg2c -lm
external/src/   \
         progs/taucs_run.c \
        -o ./obj/linux/taucs_run.o
cc  \
        -o ./bin/linux/taucs_run \
        obj/linux/taucs_run.o \
external/src/   \
         progs/iter.c \
        -o ./obj/linux/iter.o
progs/iter.c: In function ‘main’:
progs/iter.c:365: warning: ignoring return value of ‘fscanf’, declared
with
progs/iter.c:369: warning: ignoring return value of ‘fscanf’, declared
with
cc  \
        -o ./bin/linux/iter \
        obj/linux/iter.o \
mkdir obj
mkdir obj/linux/
external/src/   \
cc  \
external/src/   \
cc  \
`dgemm'
external/src/   \
cc  \
-llapack
-lmetis -lg2c -lm
external/src/   \
cc  \
-lmetis
-lg2c -lm
mkdir bin
mkdir bin/linux/
mkdir lib
mkdir lib/linux/
external/src/   \
used
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
        src/taucs_timer.c \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
declared
declared
declared
declared
external/src/   \
declared
declared
declared
declared
external/src/   \
declared
declared
declared
declared
external/src/   \
declared
declared
declared
declared
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
used
external/src/   \
used
external/src/   \
used
external/src/   \
used
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
external/src/   \
        src/taucs_iter.c \
external/src/   \
this function
this
function
this
function
external/src/   \
function
external/src/   \
external/src/   \
external/src/   \
external/src/   \
this
function
this
function
this
function
this
function
this
function
in
this function
this
function
external/src/   \
obj/linux/amdhat.o
obj/linux/colamd.o
external/src/   \
         progs/direct.c \
cc  \
external/src/   \
         progs/taucs_run.c \
cc  \
external/src/   \
         progs/iter.c \
with
with
cc  \
        obj/linux/iter.o \
Best regards
Hi Xie Yi,
Did you run "make install" (as root) after "make" in TAUCS folder?
If you did, please check that the next files exist:
    /usr/local/include/taucs_config_build.h
    /usr/local/include/taucs_config_tests.h
    /usr/local/include/taucs.h
    /usr/local/include/taucs_private.h
    /usr/local/include/blaswrap.h
    /usr/local/lib/libtaucs.a
    /usr/local/lib/libatlas.a
    /usr/local/lib/libcblas.a
    /usr/local/lib/libf77blas.a
    /usr/local/lib/libg2c.so
    /usr/local/lib/liblapack.a
    /usr/local/lib/libmetis.a
Best regards,
Laurent S.
Ce courrier électronique et toutes les pièces éventuellement jointes qu’il
contient sont CONFIDENTIELS et destinés exclusivement à l’usage de leur
destinataire. Si une erreur de transmission ou une adresse erronée a mal
dirigée ce courrier, merci d’en informer l’expéditeur en lui faisant une
réponse par courrier électronique dès réception. Si vous n’êtes pas le
destinataire de ce courrier, vous ne devez pas l’utiliser, le conserver,
en faire état, le distribuer, le copier, l’imprimer ou en révéler le
contenu à une tierce partie.
Ce courrier électronique est à usage strictement informatif et ne saurait
engager de quelque manière que ce soit SPOT IMAGE SA, ni ses filiales.
This e-mail and any attachments hereto are CONFIDENTIAL and intended
solely for the use of the addressee. If you have received this e-mail in
error please send it back to the person that sent it to you.
If you have received it in error, please notify the sender by return
email. If you are not the addressee of this email, you must not use, keep,
disseminate, copy, print or otherwise deal with it.
This email is for information only and will not bind SPOT IMAGE SA in any
contract or obligation, nor its subsidiaries.
Ce courrier électronique et toutes les pièces éventuellement jointes qu’il contient sont CONFIDENTIELS et destinés exclusivement à l’usage de leur destinataire. Si une erreur de transmission ou une adresse erronée a mal dirigée ce courrier, merci d’en informer l’expéditeur en lui faisant une réponse par courrier électronique dès réception. Si vous n’êtes pas le destinataire de ce courrier, vous ne devez pas l’utiliser, le conserver, en faire état, le distribuer, le copier, l’imprimer ou en révéler le contenu à une tierce partie.
Ce courrier électronique est à usage strictement informatif et ne saurait engager de quelque manière que ce soit SPOT IMAGE SA, ni ses filiales.
This e-mail and any attachments hereto are CONFIDENTIAL and intended solely for the use of the addressee. If you have received this e-mail in error please send it back to the person that sent it to you.
If you have received it in error, please notify the sender by return email. If you are not the addressee of this email, you must not use, keep, disseminate, copy, print or otherwise deal with it.
This email is for information only and will not bind SPOT IMAGE SA in any contract or obligation, nor its subsidiaries.
