cgal-discuss - [cgal-discuss] Re: Error by compiling poisson_reconstruction_example
  • To:
  • Subject: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example
  • Date: Fri, 25 Jun 2010 04:00:45 -0700 (PDT)
Laurent Rineau (GeometryFactory) wrote:
> Please give us the result of:
> make poisson_reconstruction_example VERBOSE=1
> The parameter VERBOSE=1 will show the compile and link flags used by
> CMake.
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
So here is the result:
abbotxie@abbotxie-laptop:~/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3$
/usr/bin/cmake
-H/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3
-B/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3
--check-build-system CMakeFiles/Makefile.cmake 0
make -f CMakeFiles/Makefile2 poisson_reconstruction_example
make[1]: Entering directory
`/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3'
/usr/bin/cmake
/usr/bin/cmake -E cmake_progress_start
/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3/CMakeFiles
1
CMakeFiles/poisson_reconstruction_example.dir/all
make[2]: Entering directory
make -f CMakeFiles/poisson_reconstruction_example.dir/build.make
CMakeFiles/poisson_reconstruction_example.dir/depend
make[3]: Entering directory
cd /home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3
&& /usr/bin/cmake -E cmake_depends "Unix Makefiles"
/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3/CMakeFiles/poisson_reconstruction_example.dir/DependInfo.cmake
--color=
Dependee
"/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3/CMakeFiles/CMakeDirectoryInformation.cmake"
is newer than depender
"/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3/CMakeFiles/poisson_reconstruction_example.dir/depend.internal".
Scanning dependencies of target poisson_reconstruction_example
make[3]: Leaving directory
/usr/bin/cmake -E cmake_progress_report
1
[100%] Building CXX object
CMakeFiles/poisson_reconstruction_example.dir/poisson_reconstruction_example.o
/usr/bin/c++ -DDEBUG_TRACE -DCGAL_USE_TAUCS -frounding-math -O3 -DNDEBUG
-I/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3/../../include
-I/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3/include
-I/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3/../../../../experimental-packages/ARAP_Parameterization/include
-I/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3/../../../Surface_mesher/include
-I/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3/../../../Point_set_processing_3/include
-I/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3/../../../Installation/include
-I/usr/local/include -I/home/abbotxie/Programs/CGAL-3.6/include -o
-c
/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3/poisson_reconstruction_example.cpp
Linking CXX executable poisson_reconstruction_example
/usr/bin/cmake -E cmake_link_script
CMakeFiles/poisson_reconstruction_example.dir/link.txt --verbose=1
/usr/bin/c++ -frounding-math -O3 -DNDEBUG
-o poisson_reconstruction_example -rdynamic
-L/home/abbotxie/Programs/CGAL-3.6/lib -L/usr/local/lib
/home/abbotxie/Programs/CGAL-3.6/lib/libCGAL_Core.so
/home/abbotxie/Programs/CGAL-3.6/lib/libCGAL.so /usr/local/lib/libmpfr.so
/usr/local/lib/libgmp.so -lboost_thread-mt /usr/local/lib/libtaucs.a
/usr/local/lib/libmetis.a /usr/local/lib/liblapack.a
/usr/local/lib/libblas.a
-Wl,-rpath,/home/abbotxie/Programs/CGAL-3.6/lib:/usr/local/lib
/usr/local/lib/libblas.a(xerbla.o): In function `xerbla_':
(.text+0x0): multiple definition of `xerbla_'
/usr/local/lib/liblapack.a(xerbla.o):xerbla.f:(.text+0x0): first defined
here
/usr/local/lib/liblapack.a(xerbla.o): In function `xerbla_':
xerbla.f:(.text+0xe): undefined reference to `s_wsfe'
xerbla.f:(.text+0x2a): undefined reference to `do_fio'
xerbla.f:(.text+0x46): undefined reference to `do_fio'
xerbla.f:(.text+0x4b): undefined reference to `e_wsfe'
xerbla.f:(.text+0x5d): undefined reference to `s_stop'
collect2: ld returned 1 exit status
make[3]: *** [poisson_reconstruction_example] Error 1
make[2]: *** [CMakeFiles/poisson_reconstruction_example.dir/all] Error 2
make[2]: Leaving directory
make[1]: *** [CMakeFiles/poisson_reconstruction_example.dir/rule] Error 2
make[1]: Leaving directory
make: *** [poisson_reconstruction_example] Error 2
Regards,
XIE, Yi
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Re-Error-by-compiling-poisson-reconstruction-example-tp2268101p2268284.html
