- To:
- Subject: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example
- Date: Fri, 25 Jun 2010 06:36:30 -0700 (PDT)
Hi, Laurent,
I just removed the Blas and Lapack with apt-get remove.
And compiled Taucs once again. With
./configure
make
sudo make install
And rm CMakeCash.txt under CGAL-3.6
And then
cmake .
make
make install
Is that right?
But still the cmake doesn't search for Blas and Lapack automatically.
If I cd to examples/Surface_reconstruction_points_3/
cmake -DCGAL_DIR=/home/abbotxie/Programs/CGAL-3.6 .
Blas and Lapack still can't be found.
I also tried to define the environment variants
BLAS_LIB_DIR=/usr/local/lib/ LAPACK_LIB_DIR=/usr/local/lib/
TAUCS_INC_DIR=/usr/local/include/ TAUCS_LIB_DIR=/usr/local/lib/ before I do
cmake. But it didn't help.
Did I do something wrong here?
Regards
XIE Yi
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Re-Error-by-compiling-poisson-reconstruction-example-tp2268101p2268465.html
- Re: [cgal-discuss] Error by compiling poisson_reconstruction_example, (continued)
- Re: [cgal-discuss] Error by compiling poisson_reconstruction_example, Laurent Saboret, 06/25/2010
- [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Xie Yi, 06/25/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Saboret, 06/25/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Rineau (GeometryFactory), 06/25/2010
- [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Xie Yi, 06/28/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Saboret, 06/29/2010
- [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Xie Yi, 06/29/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Saboret, 06/30/2010
