cgal-discuss - Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?
  • To:
  • Subject: Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?
  • Date: Mon, 25 Oct 2010 09:08:24 +0200
Sebastian Kapfer wrote:
Hi,
The problem is due to floating point rounding.
Depending of the optimization done by the compiler an expression
was not evaluated the same way.
For convenience, I made a fix which solve the "problem" on my machine (patch file attached).
Thank you, the fix solves the problem for me.
Will this fix be in future versions of CGAL? I'm not sure if you
consider it a 'real' problem since you put the quotation marks around
"problem". :-)
The fix will appear in the next release of CGAL.
