cgal-discuss - Re: [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted
  • To:
  • Subject: Re: [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted
  • Date: Wed, 09 Feb 2011 18:27:55 +0100
Here are two versions compiling and working,
but with different output!
main.cpp: since the constructor with range of alpha shape is used (which
is calling then the constructor with range of the Delaunay triangulation
the order in which the points are inserted in not the same than the one
in the sequence). This is why I introduced a map which
If you want to keep track of the original insertion order, look at this
thread:
https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2010-01/msg00003.html
main-esbtl.cpp:This example uses the ESBTL library (http://esbtl.sourceforge.net/) to read your input pdbfile.
It uses a kernel where points are atoms and thus you can access their
atom serial number and print it.
S.
MrVH wrote:
Thank you for your anwser. It's really unclear for me.
it doesn't work :( To answer you about point, I just want to now the
belonging of my point to tetraedra/facets/Edge
input
coord
1 x y z w
2 x y z w
output
Results (results of Alpha Shape)
edges 1 2
edges 4 24
Tetrehedron 1 4 6 2
Triangles 78 4 3
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Regular_triangulation_euclidean_traits_3<K> Gt;
typedef CGAL::Alpha_shape_vertex_base_3<Gt> Vb;
typedef CGAL::Alpha_shape_cell_base_3<Gt> Fb;
typedef CGAL::Triangulation_data_structure_3<Vb,Fb> Tds;
typedef CGAL::Regular_triangulation_3<Gt,Tds> Triangulation_3;
typedef CGAL::Alpha_shape_3<Triangulation_3> Alpha_shape_3;
typedef Alpha_shape_3::Cell_handle Cell_handle;
typedef Alpha_shape_3::Vertex_handle Vertex_handle;
typedef Alpha_shape_3::Facet Facet;
typedef Alpha_shape_3::Edge Edge;
typedef Gt::Weighted_point Weighted_point;
typedef Gt::Bare_point Bare_point;
/*TEST AREA*/
typedefTriple<Cell_handle, int, int> Edge; // does not compile
typedef std::pair<Cell_handle, int> Facet;
int main()
std::list<Weighted_point> lwp;
ifstream fpdb;
fpdb.open("1GXD.pdb");
string line;
while (getline(fpdb, line)){
/* Get coordinates*/
string type(line.substr(0,4));
if (type != "ATOM"){continue;}
string xstr(line.substr(30,8));
string ystr(line.substr(38,8));
string zstr(line.substr(46,8));
float x = atof(xstr.c_str());
float y = atof(ystr.c_str());
float z = atof(zstr.c_str());
lwp.push_back(Weighted_point(Bare_point( x, y, z), 1.80));
fpdb.close();
//build alpha_shape in GENERAL mode and set alpha=0
Alpha_shape_3 as(lwp.begin(), lwp.end(), 0, Alpha_shape_3::GENERAL);
//explore the 0-shape - It is dual to the boundary of the union.
//CGAL::Triangulation_data_structure_3::Cell_handle cells;
std::list<Cell_handle> cells;
std::list<Facet> facets;
std::list<Edge> edges;
//as.get_alpha_shape_cells(std::back_inserter(cells),
Alpha_shape_3::INTERIOR);
as.get_alpha_shape_facets(std::back_inserter(facets),
Alpha_shape_3::REGULAR);
Alpha_shape_3::SINGULAR);
as.get_alpha_shape_edges(std::back_inserter(edges),
std::map<Alpha_shape_3::Vertex*,unsigned int> index;
unsigned int i=0;
for (Alpha_shape_3::Finite_vertices_iterator
vit=as.finite_vertices_begin();vit!=as.finite_vertices_end();++vit)
{index.insert(std::make_pair(&(*vit)),i++); }
for (int k=0;k<4;++k) std::cout << index[ &( *(cells->vertex(k)) ) ];
std::cout <<std::endl;
for (k=0;k<3;++k)
std::cout << index[ &(*(facet.first->vertex( (facets.second+k)%4 )))];
std::cout << index[ &(*(edges.first->vertex( edges.second )))] <<" ";
std::cout << index[ &(*(edges.first->vertex( edges.third )))];
std::cout <<std::endl; /*
std::list<Edge>::iterator fbeg = edges.begin();
std::list<Edge>::iterator fend = edges.end();
for (fbeg; fbeg != fend; fbeg++){
std::cout << fbeg.first << std::endl;
for (Alpha_Shape_Edges_Iterator edge_alpha_it=edges.alpha_begin();
edge_alpha_it!=edges.alpha_end(); edge_alpha_it++)
Alpha_Edge& edge = *edge_alpha_it;
const Point_2& p1 =
edge.first->vertex(edge.first->ccw(edge.second))->point();
const Point_2& p2 = edge.first->vertex(edge.first->cw
(edge.second))->point(); std::cout << p1 << p2 << endl;
// std::ifstream iFileT("output",std::ios::in);
//iFileT >> as;
std::cout << "TOTO" << std::endl;
//std::cout << cells.neighbor(1) << std::endl;
std::cout << " The 0-shape has : " << std::endl;
//std::cout << cells.size() << " interior tetrahedra" << std::endl;
std::cout << facets.size() << " boundary facets" << std::endl;
std::cout << edges.size() << " singular edges" << std::endl;
return 1;
#include <CGAL/Regular_triangulation_euclidean_traits_3.h>
#include <CGAL/Regular_triangulation_3.h>
#include <CGAL/Alpha_shape_3.h>
#include <fstream>
#include <iostream>
int main()
  std::ifstream fpdb;
  std::string line;
  while (std::getline(fpdb, line)){
	std::string type(line.substr(0,4));
	std::string xstr(line.substr(30,8));
	std::string ystr(line.substr(38,8));
	std::string zstr(line.substr(46,8));
  fpdb.close();
  std::cout << "read " << lwp.size() << " atoms" << std::endl;
  as.get_alpha_shape_cells(std::back_inserter(cells),Alpha_shape_3::INTERIOR);
  as.get_alpha_shape_facets(std::back_inserter(facets),Alpha_shape_3::REGULAR);
  as.get_alpha_shape_facets(std::back_inserter(facets),Alpha_shape_3::SINGULAR);
  as.get_alpha_shape_edges(std::back_inserter(edges),Alpha_shape_3::SINGULAR);
  //set index of each vertex
  unsigned int i=0;
  for (Alpha_shape_3::Finite_vertices_iterator vit=as.finite_vertices_begin();vit!=as.finite_vertices_end();++vit)
    index.insert(std::make_pair(&(*vit),i++));
  for (std::list<Cell_handle>::iterator cell=cells.begin();cell!=cells.end();++cell){
    std::cout << "cell ";
    for (int k=0;k<4;++k) std::cout << index[ &( *((*cell)->vertex(k)) ) ] << " ";
  for (std::list<Facet>::iterator facet=facets.begin();facet!=facets.end();++facet){
    std::cout << "facet ";
    for (int k=0;k<3;++k)
      std::cout << index[ &(*(facet->first->vertex( (facet->second+k)%4 )))] << " ";
  for (std::list<Edge>::iterator edge=edges.begin();edge!=edges.end();++edge)
    std::cout << "edge ";
    std::cout << index[ &(*(edge->first->vertex( edge->second )))] <<" ";
    std::cout << index[ &(*(edge->first->vertex( edge->third )))] <<std::endl;
  return 1;
//ESBTL include
#include <ESBTL/default.h>
#include <ESBTL/weighted_atom_iterator.h>
#include <ESBTL/CGAL/EPIC_kernel_with_atom.h>
#include <ESBTL/atom_classifier.h>
#include <fstream>
#include <iostream>
//Kernel from ESBTL
typedef ESBTL::CGAL::EPIC_kernel_with_atom                   K;
//CGAL stuff
//ESBTL stuff
typedef ESBTL::CGAL::Default_system                                                 System;
typedef ESBTL::Generic_classifier<ESBTL::Radius_of_atom<double,System::Atom> >      T_Atom_classifier;
typedef ESBTL::Accept_none_occupancy_policy<ESBTL::PDB::Line_format<> >             Accept_none_occupancy_policy;
typedef ESBTL::Weighted_atom_iterator<System::Model,
                                      CGAL::Weighted_point<K::Point_3,double>,
                                      ESBTL::Weight_of_atoms<T_Atom_classifier> >   Weighted_atom_iterator;
int main(int argc,char** argv)
  if (argc != 2 ){
    std::cerr << "Please provide a filename"  << std::endl;
    return EXIT_FAILURE;
  ESBTL::PDB_line_selector_two_systems sel;
  std::vector<System> systems;
  ESBTL::All_atom_system_builder<System> builder(systems,sel.max_nb_systems());
  T_Atom_classifier atom_classifier;
    //read pdb file
  ESBTL::read_a_pdb_file(argv[1],sel,builder,Accept_none_occupancy_policy());
  if ( systems.empty() || systems[0].has_no_model() ){
    std::cerr << "No atoms found" << std::endl;
  //Consider only the first model of the first system
  const System::Model& model=*systems[0].models_begin();
  Alpha_shape_3  as(  Weighted_atom_iterator(model.atoms_begin(),&atom_classifier),
                      Weighted_atom_iterator(model.atoms_end(),&atom_classifier),
                      0, Alpha_shape_3::GENERAL );
    for (int k=0;k<4;++k) std::cout << (*cell)->vertex(k)->point().atom_serial_number() << " ";
      std::cout << facet->first->vertex( (facet->second+k)%4 )->point().atom_serial_number() << " ";
    std::cout << edge->first->vertex( edge->second )->point().atom_serial_number() <<" ";
    std::cout << edge->first->vertex( edge->third )->point().atom_serial_number() <<std::endl;
  return 1;
# CMAKE generated file: DO NOT EDIT!
# Generated by "Unix Makefiles" Generator, CMake Version 2.8
# Default target executed when no arguments are given to make.
default_target: all
.PHONY : default_target
# Special targets provided by cmake.
# Disable implicit rules so canoncical targets will work.
.SUFFIXES:
# Remove some rules from gmake that .SUFFIXES does not remove.
SUFFIXES =
.SUFFIXES: .hpux_make_needs_suffix_list
# Suppress display of executed commands.
$(VERBOSE).SILENT:
# A target that is always out of date.
cmake_force:
.PHONY : cmake_force
# Set environment variables for the build.
# The shell in which to execute make rules.
SHELL = /bin/sh
# The CMake executable.
CMAKE_COMMAND = /usr/bin/cmake
# The command to remove a file.
RM = /usr/bin/cmake -E remove -f
# The program to use to edit the cache.
CMAKE_EDIT_COMMAND = /usr/bin/ccmake
# The top-level source directory on which CMake was run.
CMAKE_SOURCE_DIR = /tmp/as
# The top-level build directory on which CMake was run.
CMAKE_BINARY_DIR = /tmp/as
# Targets provided globally by CMake.
# Special rule for the target edit_cache
edit_cache:
@$(CMAKE_COMMAND) -E cmake_echo_color --switch=$(COLOR) --cyan
"Running CMake cache editor..."
/usr/bin/ccmake -H$(CMAKE_SOURCE_DIR) -B$(CMAKE_BINARY_DIR)
.PHONY : edit_cache
edit_cache/fast: edit_cache
.PHONY : edit_cache/fast
# Special rule for the target rebuild_cache
rebuild_cache:
"Running CMake to regenerate build system..."
/usr/bin/cmake -H$(CMAKE_SOURCE_DIR) -B$(CMAKE_BINARY_DIR)
.PHONY : rebuild_cache
rebuild_cache/fast: rebuild_cache
.PHONY : rebuild_cache/fast
# The main all target
all: cmake_check_build_system
$(CMAKE_COMMAND) -E cmake_progress_start /tmp/as/CMakeFiles
/tmp/as/CMakeFiles/progress.marks
$(MAKE) -f CMakeFiles/Makefile2 all
$(CMAKE_COMMAND) -E cmake_progress_start /tmp/as/CMakeFiles 0
.PHONY : all
# The main clean target
clean:
$(MAKE) -f CMakeFiles/Makefile2 clean
.PHONY : clean
clean/fast: clean
.PHONY : clean/fast
# Prepare targets for installation.
preinstall: all
$(MAKE) -f CMakeFiles/Makefile2 preinstall
.PHONY : preinstall
preinstall/fast:
.PHONY : preinstall/fast
# clear depends
depend:
$(CMAKE_COMMAND) -H$(CMAKE_SOURCE_DIR) -B$(CMAKE_BINARY_DIR)
--check-build-system CMakeFiles/Makefile.cmake 1
.PHONY : depend
# Target rules for targets named main
# Build rule for target.
main: cmake_check_build_system
$(MAKE) -f CMakeFiles/Makefile2 main
.PHONY : main
# fast build rule for target.
main/fast:
$(MAKE) -f CMakeFiles/main.dir/build.make CMakeFiles/main.dir/build
.PHONY : main/fast
# Target rules for targets named main-esbtl
main-esbtl: cmake_check_build_system
$(MAKE) -f CMakeFiles/Makefile2 main-esbtl
.PHONY : main-esbtl
main-esbtl/fast:
$(MAKE) -f CMakeFiles/main-esbtl.dir/build.make
.PHONY : main-esbtl/fast
# target to build an object file
main-esbtl.o:
CMakeFiles/main-esbtl.dir/main-esbtl.o
.PHONY : main-esbtl.o
# target to preprocess a source file
main-esbtl.i:
CMakeFiles/main-esbtl.dir/main-esbtl.i
.PHONY : main-esbtl.i
# target to generate assembly for a file
main-esbtl.s:
CMakeFiles/main-esbtl.dir/main-esbtl.s
.PHONY : main-esbtl.s
main.o:
$(MAKE) -f CMakeFiles/main.dir/build.make CMakeFiles/main.dir/main.o
.PHONY : main.o
main.i:
$(MAKE) -f CMakeFiles/main.dir/build.make CMakeFiles/main.dir/main.i
.PHONY : main.i
main.s:
$(MAKE) -f CMakeFiles/main.dir/build.make CMakeFiles/main.dir/main.s
.PHONY : main.s
# Help Target
help:
@echo "The following are some of the valid targets for this Makefile:"
@echo "... all (the default if no target is provided)"
@echo "... clean"
@echo "... depend"
@echo "... edit_cache"
@echo "... main"
@echo "... main-esbtl"
@echo "... rebuild_cache"
@echo "... main-esbtl.o"
@echo "... main-esbtl.i"
@echo "... main-esbtl.s"
@echo "... main.o"
@echo "... main.i"
@echo "... main.s"
.PHONY : help
# Special targets to cleanup operation of make.
# Special rule to run CMake to check the build system integrity.
# No rule that depends on this can have commands that come from listfiles
# because they might be regenerated.
cmake_check_build_system:
--check-build-system CMakeFiles/Makefile.cmake 0
.PHONY : cmake_check_build_system
