cgal-discuss - [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted
  • To:
  • Subject: [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted
  • Date: Fri, 11 Feb 2011 00:02:28 -0800 (PST)
I'm trying to understand your mapping code and to modify it. But I've got
some compilation errors and I don't catch some lines. I really have to use
this code cause to avoid to recode AlphaShape Weighted from scratch in
Python :(
I don't see where the Delaunay function is launched.
In main I'm running:
Alpha_shape_3 as;
build_triangulation_with_indices(lwp.begin(),lwp.end(),as);
The build_triangulation_with_indices function take now an Alpha_Shape_3
object:
//function inserting points into a triangulation
//and setting the info field to the order in the input list.
template <class Alpha_Shape_3,class Point_iterator>
void
Point_iterator begin,
Point_iterator end,
Alpha_Shape_3& T)
// The vector is now a Weighted_point vector cause it is regular
triangulation
std::vector<std::pair<const typename Gt::Weighted_point*,int> > points;
int index=-1;
for (Point_iterator it=begin;it!=end;++it){
points.push_back(std::make_pair(&(*it),++index));
std::random_shuffle (points.begin(), points.end()); // shuffle point but
why ???
spatial_sort (points.begin(),points.end(),
Traits_for_spatial_sort<Alpha_Shape_3>()); // build a structure struct
Traits_for_spatial_sort:public Alpha_Shape_3::Geom_traits
// from here I do not understand. Where Trigulation is launched ???
typename Alpha_Shape_3::Cell_handle hint;
for (typename std::vector< std::pair<const typename
Gt::Weighted_point*,int> >::const_iterator
p = points.begin();p != points.end(); ++p)
typename Alpha_Shape_3::Locate_type lt;
typename Alpha_Shape_3::Cell_handle c;
int li, lj;
c = T.locate (*(p->first), lt, li, lj, hint);
typename Alpha_Shape_3::Vertex_handle v = T.insert (*(p->first), lt, c,
li, lj);
if ( v==typename Alpha_Shape_3::Vertex_handle() )
hint=c;
else{
v->info() = p->second ;
hint=v->cell();
the structure
//typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Triangulation_vertex_base_with_info_3<int, K> Wb; // avoid
conflict so Wb instead of Vb cause casting is different than the previous
<int, K>
typedef CGAL::Triangulation_data_structure_3<Wb> Tds2;
typedef CGAL::Delaunay_triangulation_3<K, Tds2>
Delaunay; // avoir conflict
typedef Delaunay::Point Point;
//spatial sort traits to use with a pair of point pointers and integer.
template<class Alpha_Shape_3>
struct Traits_for_spatial_sort:public Alpha_Shape_3::Geom_traits{
typedef typename Alpha_Shape_3::Geom_traits Gt;
typedef std::pair<const typename Gt::Weighted_point*,int> Point_3;
struct Less_x_3{
bool operator()(const Point_3& p,const Point_3& q) const {
return typename Gt::Less_x_3()(*(p.first),*(q.first));
struct Less_y_3{
return typename Gt::Less_y_3()(*(p.first),*(q.first));
struct Less_z_3{
return typename Gt::Less_z_3()(*(p.first),*(q.first));
Less_x_3 less_x_3_object () const {return Less_x_3();}
Less_y_3 less_y_3_object () const {return Less_y_3();}
Less_z_3 less_z_3_object () const {return Less_z_3();}
Thank you for your help and your explanations,
The full code:
#include <CGAL/Regular_triangulation_euclidean_traits_3.h>
#include <CGAL/Regular_triangulation_3.h>
#include <CGAL/Alpha_shape_3.h>
#include <fstream>
#include <iostream>
#include <cstdio>
#include <cstring>
#include <string>
#include <map>
#include <set>
#include <vector>
#include <cmath>
#include <stdio.h>
#include <stdlib.h>
//#include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
#include <CGAL/Delaunay_triangulation_3.h>
#include <CGAL/Triangulation_vertex_base_with_info_3.h>
//#include <iostream>
typedef CGAL::Regular_triangulation_euclidean_traits_3<K> Gt;
typedef CGAL::Alpha_shape_vertex_base_3<Gt> Vb;
typedef CGAL::Alpha_shape_cell_base_3<Gt> Fb;
typedef CGAL::Triangulation_data_structure_3<Vb,Fb> Tds;
typedef CGAL::Regular_triangulation_3<Gt,Tds> Triangulation_3;
typedef CGAL::Alpha_shape_3<Triangulation_3> Alpha_shape_3;
typedef Alpha_shape_3::Cell_handle Cell_handle;
typedef Alpha_shape_3::Vertex_handle Vertex_handle;
typedef Alpha_shape_3::Facet Facet;
typedef Alpha_shape_3::Edge Edge;
typedef Gt::Weighted_point Weighted_point;
typedef Gt::Bare_point Bare_point;
Delaunay;
struct Less_x_3{
struct Less_y_3{
struct Less_z_3{
void
Point_iterator end,
Alpha_Shape_3& T)
int index=-1;
int li, lj;
li, lj);
hint=c;
else{
hint=v->cell();
int main(int argc, char *argv[])
std::list<Weighted_point> lwp;
/*Get arguments*/
char *filename = argv[1]; // Format of file %8.3f%8.3f%8.3f%8.3f, x, y,
z, weight
float sizeas = atof(argv[2]); // size of AlphaSphere
std::cout << "# File" << filename << std::endl;
/*Read the file*/
std::ifstream fcoords;
fcoords.open(filename);
std::string line;
while (std::getline(fcoords, line)){
/* Get coordinates*/
std::string type(line.substr(0,1));
if (type == "#" || type == "\n"){continue;} // comment line
std::string xstr(line.substr(0,8));
std::string ystr(line.substr(8,8));
std::string zstr(line.substr(16,8));
std::string weightstr(line.substr(24,8));
//std::cout << xstr << ystr << zstr << weightstr << std::endl;
float x = atof(xstr.c_str());
float y = atof(ystr.c_str());
float z = atof(zstr.c_str());
float weight = atof(weightstr.c_str());
/* fill each point with its associate weight */
lwp.push_back(Weighted_point(Bare_point( x, y, z), weight));
fcoords.close();
std::cout << "# read " << lwp.size() << " atoms" << std::endl;
/* Launch AlphaShape*/
//Alpha_shape_3 as(lwp.begin(), lwp.end(), sizeas,
Alpha_shape_3::GENERAL);
Alpha_shape_3 as;
/* Create empty storage*/
std::list<Cell_handle> cells;
std::list<Facet> facets;
std::list<Edge> edges;
/*Get information
Cell -> Tetraedron
Facet -> Triangle
Edge -> segment
as.get_alpha_shape_cells(std::back_inserter(cells),Alpha_shape_3::INTERIOR);
as.get_alpha_shape_facets(std::back_inserter(facets),Alpha_shape_3::REGULAR);
as.get_alpha_shape_facets(std::back_inserter(facets),Alpha_shape_3::SINGULAR);
as.get_alpha_shape_edges(std::back_inserter(edges),Alpha_shape_3::SINGULAR);
/* Enumeration */
std::map<Alpha_shape_3::Vertex*,unsigned int> index;
unsigned int i=0;
for (Alpha_shape_3::Finite_vertices_iterator
vit=as.finite_vertices_begin();vit!=as.finite_vertices_end();++vit)
index.insert(std::make_pair(&(*vit),i++));
/* Tetrahedron*/
for (std::list<Cell_handle>::iterator
cell=cells.begin();cell!=cells.end();++cell){
std::cout << "cell ";
//for (int k=0;k<4;++k) std::cout << index[ &( *((*cell)->vertex(k)) ) ]
//std::cout <<std::endl;
for (int k=0;k<4;++k) std::cout << (*cell)->vertex(k)->point() << " ";
/* Triangle */
for (std::list<Facet>::iterator
facet=facets.begin();facet!=facets.end();++facet){
std::cout << "facet ";
for (int k=0;k<3;++k)
std::cout << (facet->first->vertex( (facet->second+k)%4 ))->point() <<
//std::cout << index[ &(*(facet->first->vertex( (facet->second+k)%4
/* Edge */
for (std::list<Edge>::iterator
edge=edges.begin();edge!=edges.end();++edge)
std::cout << "edge ";
std::cout << (edge->first->vertex( edge->second ))->point() <<" ";
std::cout << (edge->first->vertex( edge->third ))->point() << std::endl;
//std::cout << index[ &(*(edge->first->vertex( edge->second )))] <<" ";
//std::cout << index[ &(*(edge->first->vertex( edge->third )))]
<<std::endl;
std::cout << "# The 0-shape has : " << std::endl;
std::cout << "# " << cells.size() << " interior tetrahedra" << std::endl;
std::cout << "# " << facets.size() << " boundary facets" << std::endl;
std::cout << "# " << edges.size() << " singular edges" << std::endl;
return 1;
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Screen-easely-Cells-Facets-Edges-AlphaShape3D-Weighted-tp3297041p3300898.html
