cgal-discuss - [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted
  • To:
  • Subject: [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted
  • Date: Fri, 11 Feb 2011 05:34:38 -0800 (PST)
I try to test the ESBTL lib with your script to see the difference, but I
didn't pass to launch your cmake (direct crashed), so I created a cmake
following some examples works but the make doesn't work after...
# Created by the script cgal_create_cmake_script
# This is the CMake script for compiling a CGAL application.
project( test_example )
CMAKE_MINIMUM_REQUIRED(VERSION 2.4.5)
set (CMAKE_BUILD_TYPE Debug)
#~ find_package(BOOST)
#~ if ( BOOST_FOUND )
include_directories(/usr/local/include)
include_directories(/home/user/ESBTL-1.0-beta01/include)
include_directories(/usr/include)
include_directories(/home/user/boost_1_45_0/boost)
include_directories(/home/user/boost_1_45_0)
add_executable(AlphaShape AlphaShape.cpp)
#~ else()
#~ message(STATUS "This program requires the BOOST library, and will not
be compiled.")
#~ endif()
other test failed:
project( examples_example )
set(CMAKE_ALLOW_LOOSE_LOOP_CONSTRUCTS true)
find_package(CGAL QUIET COMPONENTS Core )
if ( CGAL_FOUND )
include( ${CGAL_USE_FILE} )
include( CGAL_CreateSingleSourceCGALProgram )
# include_directories (BEFORE ../../include)
/home/sloriot/CGAL/install/trunk/Skin_surface_3/include)
# add_executable(AlphaShape AlphaShape.cpp)
create_single_source_cgal_program( "AlphaShape.cpp" )
# create_single_source_cgal_program( "coarse_grain_triang.cpp" )
#link_libraries(boost_regex reader)
else()
message(STATUS "This program requires the CGAL library, and will not be
compiled.")
endif()
error :
CMakeFiles/AlphaShape.dir/AlphaShape.o: In function `__tcf_1':
AlphaShape.cpp:(.text+0x1ac): undefined reference to
`boost::detail::set_tss_data(void const*,
boost::shared_ptr<boost::detail::tss_cleanup_function>, void*, bool)'
`CGAL::Triangulation_data_structure_3<CGAL::Alpha_shape_vertex_base_3<CGAL::Regular_triangulation_euclidean_traits_3<CGAL::Filtered_kernel<ESBTL::CGAL::Kernel_with_atom<double>,
true>, double, true>,
CGAL::Triangulation_vertex_base_3<CGAL::Regular_triangulation_euclidean_traits_3<CGAL::Filtered_kernel<ESBTL::CGAL::Kernel_with_atom<double>,
true>, double, true>, CGAL::Triangulation_ds_vertex_base_3<void> > >,
CGAL::Alpha_shape_cell_base_3<CGAL::Regular_triangulation_euclidean_traits_3<CGAL::Filtered_kernel<ESBTL::CGAL::Kernel_with_atom<double>,
CGAL::Triangulation_cell_base_3<CGAL::Regular_triangulation_euclidean_traits_3<CGAL::Filtered_kernel<ESBTL::CGAL::Kernel_with_atom<double>,
true>, double, true>, CGAL::Triangulation_ds_cell_base_3<void> > >
>::create_star_3(CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_vertex_base_3<CGAL::Regular_triangulation_euclidean_traits_3<CGAL::Filtered_kernel<ESBTL::CGAL::Kernel_with_atom<double>,
CGAL::Triangulation_ds_vertex_base_3<CGAL::Triangulation_data_structure_3<CGAL::Alpha_shape_vertex_base_3<CGAL::Regular_triangulation_euclidean_traits_3<CGAL::Filtered_kernel<ESBTL::CGAL::Kernel_with_atom<double>,
true>, double, true>, CGAL::Triangulation_ds_cell_base_3<void> > > > > > >,
CGAL::Default>, false>,
CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_cell_base_3<CGAL::Regular_triangulation_euclidean_traits_3<CGAL::Filtered_kernel<ESBTL::CGAL::Kernel_with_atom<double>,
CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Alpha_shape_vertex_base_3<CGAL::Regular_triangulation_euclidean_traits_3<CGAL::Filtered_kernel<ESBTL::CGAL::Kernel_with_atom<double>,
CGAL::Default>, false>, int, int)':
AlphaShape.cpp:(.text._ZN4CGAL30Triangulation_data_structure_3INS_25Alpha_shape_vertex_base_3INS_40Regular_triangulation_euclidean_traits_3INS_15Filtered_kernelIN5ESBTL4CGAL16Kernel_with_atomIdEELb1EEEdLb1EEENS_27Triangulation_vertex_base_3IS9_NS_30Triangulation_ds_vertex_base_3IvEEEEEENS_23Alpha_shape_cell_base_3IS9_NS_25Triangulation_cell_base_3IS9_NS_28Triangulation_ds_cell_base_3IvEEEEEEE13create_star_3ENS_8internal11CC_iteratorINS_17Compact_containerINS1_IS9_NSA_IS9_NSB_ISL_EEEEEENS_7DefaultEEELb0EEENSN_INSO_INSF_IS9_NSG_IS9_NSH_ISL_EEEEEESS_EELb0EEEii[CGAL::Triangulation_data_structure_3<CGAL::Alpha_shape_vertex_base_3<CGAL::Regular_triangulation_euclidean_traits_3<CGAL::Filtered_kernel<ESBTL::CGAL::Kernel_with_atom<double>,
CGAL::Default>, false>, int, int)]+0xec): undefined reference to
`boost::detail::get_tss_data(void const*)'
CGAL::Default>, false>, int, int)]+0x100): undefined reference to
CGAL::Default>, false>, int, int)]+0x4a7): undefined reference to
CGAL::Default>, false>, int, int)]+0x4ed): undefined reference to
CGAL::Default>, false>, int, int)]+0x52c): undefined reference to
collect2: ld a retourné 1 code d'état d'exécution
make[2]: *** [AlphaShape] Erreur 1
make[1]: *** [CMakeFiles/AlphaShape.dir/all] Erreur 2
make: *** [all] Erreur 2
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Screen-easely-Cells-Facets-Edges-AlphaShape3D-Weighted-tp3297041p3301276.html
