cgal-discuss - Re: [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted
  • To:
  • Subject: Re: [cgal-discuss] Re: Screen easely Cells, Facets, Edges, AlphaShape3D Weighted
  • Date: Fri, 11 Feb 2011 14:41:54 +0100
MrVH wrote:
Thank you it works ! ;)
But there are some issues in the results. I have got some big edge even with a small Alpha (=0.0)
I take the same weight for each point for example. When I process the AlphaShape 0.0 normaly the maximum distance is
2*ray_alpha_shape + 2*weight so in my example i put 1.8 for weight at each
point and the result is that I've got edge mesurement at more than 10 !
How it is possible, do I understand bad ?
I have to admit I don't understand what you said.
You are writing that you set alpha to 0 and the weight of each point is
1.8 (i.e. the squared radius of the corresponding ball is 1.8).
Then you are looking at the squared distance between the points of a
singular edge, and this squared distance is 10?
This is indeed not possible, but again I am not sure I got you.
S.
