- To:
- Subject: Re: [cgal-discuss] Finite Element Analysis
- Date: Fri, 18 Mar 2011 09:09:36 +0100
Christoph Weber wrote:
Hi,By curiosity, why do you prefer using TetGen than CGAL's Mesh_3 to
I'm working a similar subject. If you are just looking for a tool, I
would emphasize TetGen. It is open source, dokumented and focused on
FE-Meshes.
generate FE-Meshes?
The Polyhedron demo has a plugin that allows to generate 3D meshes from
an off file (Operations->Create a tetrahedral mesh).
S.
regs, Christoph
Am Donnerstag, den 17.03.2011, 12:53 -0500 schrieb Fabio Casado Ruiz:
Hi. I'm studying several tools and libraries for mesh generation to use in Finite element Analysis. Has anyone used CGAL for this purposes or has any knowledge where to read about its pros and cons for this purpose???
Thanks a lot..
F.
- [cgal-discuss] Finite Element Analysis, Fabio Casado Ruiz, 03/17/2011
- Re: [cgal-discuss] Finite Element Analysis, Christoph Weber, 03/18/2011
- Re: [cgal-discuss] Finite Element Analysis, Sebastien Loriot (GeometryFactory), 03/18/2011
- Re: [cgal-discuss] Finite Element Analysis, Fabio Casado Ruiz, 03/19/2011
- Re: [cgal-discuss] Finite Element Analysis, Pedro Machado Manhães de Castro, 03/19/2011
- Re: [cgal-discuss] Finite Element Analysis, Daniel Duque, 03/20/2011
- Re: [cgal-discuss] Finite Element Analysis, Qianqian Fang, 03/21/2011
- Re: [cgal-discuss] Finite Element Analysis, Sebastien Loriot (GeometryFactory), 03/21/2011
- Re: [cgal-discuss] Finite Element Analysis, Laurent Rineau (GeometryFactory), 03/21/2011
