cgal-discuss - Re: [cgal-discuss] Finite Element Analysis
  • To:
  • Subject: Re: [cgal-discuss] Finite Element Analysis
  • Date: Mon, 21 Mar 2011 18:56:40 +0100
Le lundi 21 mars 2011 18:33:26, Qianqian Fang a écrit :
> On 03/21/2011 10:47 AM, Sebastien Loriot (GeometryFactory) wrote:
> >> http://nmr.mgh.harvard.edu/~fangq/temp/post_extract.off
> > Your off file contains triangles that are not consistently oriented
> > to describe a polyhedron. You need to reorient triangles.
> > If you use the Polyhedron demo of CGAL, do:
> > "Operations -> Orient polygon soup"
> > To produce a 3D mesh you can then do:
> > Save in back to an off file and reload it.
> > Then do:
> > "Operation -> Create a tetrahedral mesh"
> > or directly use your code.
> I used JMeshLib (http://jmeshlib.sourceforge.net/) to reorient
> all triangles, but the output surface mesh still crashed the
> polyhedral mesher. The surface meshes before and after
> the reorientation can be found here
> http://nmr.mgh.harvard.edu/~fangq/temp/pre_cgalpoly.off
> http://nmr.mgh.harvard.edu/~fangq/temp/pre_cgalpoly_reorder.off
> any more comments?
I tried the example CGAL-3.8-beta1/examples/Mesh_3/mesh_polyhedral_domain.cpp on your file, with a small change to the criteria (facet_size=4, facet_distance=0.04, cell_size=4), and it produced a mesh of 23196 vertices.
What source code do you use? I checkouted from the SVN of iso2mesh but you do not provide the source code of cgalmesh.exe.
Laurent Rineau, PhD
