- To:
- Subject: Re: [cgal-discuss] Finite Element Analysis
- Date: Fri, 18 Mar 2011 19:24:56 -0500 (CST)
I'm actually doing a research as to which advantage or disadvantage several
tools and librarys have for FE Mesh generation. Any suggestions or articles
about this subject? Are CGAL mesh generation and refinement algorithms
optimal for FEMeshes?
----- Original Message -----
To:
Sent: Fri, 18 Mar 2011 03:24:56 -0500 (CST)
oh, I didn't knew that... I worked a little with CGAL. Sorry for my rash
answer..
Am Freitag, den 18.03.2011, 09:09 +0100 schrieb Sebastien Loriot
(GeometryFactory):
> Christoph Weber wrote:
> > Hi,
> > I'm working a similar subject. If you are just looking for a tool, I
> > would emphasize TetGen. It is open source, dokumented and focused on
> > FE-Meshes.
> By curiosity, why do you prefer using TetGen than CGAL's Mesh_3 to
> generate FE-Meshes?
> The Polyhedron demo has a plugin that allows to generate 3D meshes from
> an off file (Operations->Create a tetrahedral mesh).
> S.
> > regs, Christoph
> > Am Donnerstag, den 17.03.2011, 12:53 -0500 schrieb Fabio Casado Ruiz:
> >> Hi. I'm studying several tools and libraries for mesh generation to use
> >> in Finite element Analysis. Has anyone used CGAL for this purposes or
> >> has any knowledge where to read about its pros and cons for this
> >> purpose???
> >> Thanks a lot..
> >> F.
Dipl.-Phys. Christoph Weber
Institut für Kontinuumsmechanik
G.W.Leibniz Universität Hannover
Appelstraße 11
D-30167 Hannover
Tel.: +49-511-762-4135
Fax.: +49-511-762-5496
e-mail:
Internet: www.ikm.uni-hannover.de
ECCOMAS Thematic Conference 2011: www.icccm11.uni-hannover.de
__________________________________________________
- [cgal-discuss] Finite Element Analysis, Fabio Casado Ruiz, 03/17/2011
- Re: [cgal-discuss] Finite Element Analysis, Christoph Weber, 03/18/2011
- Re: [cgal-discuss] Finite Element Analysis, Sebastien Loriot (GeometryFactory), 03/18/2011
- Re: [cgal-discuss] Finite Element Analysis, Fabio Casado Ruiz, 03/19/2011
- Re: [cgal-discuss] Finite Element Analysis, Pedro Machado Manhães de Castro, 03/19/2011
- Re: [cgal-discuss] Finite Element Analysis, Daniel Duque, 03/20/2011
- Re: [cgal-discuss] Finite Element Analysis, Qianqian Fang, 03/21/2011
- Re: [cgal-discuss] Finite Element Analysis, Sebastien Loriot (GeometryFactory), 03/21/2011
- Re: [cgal-discuss] Finite Element Analysis, Laurent Rineau (GeometryFactory), 03/21/2011
