- To:
- Subject: Re: [cgal-discuss] Finite Element Analysis
- Date: Mon, 21 Mar 2011 18:45:52 +0100
Qianqian Fang wrote:
On 03/21/2011 10:47 AM, Sebastien Loriot (GeometryFactory) wrote:Can you provide the code, because it is working fine for me.
http://nmr.mgh.harvard.edu/~fangq/temp/post_extract.off
Your off file contains triangles that are not consistently oriented
to describe a polyhedron. You need to reorient triangles.
If you use the Polyhedron demo of CGAL, do:
"Operations -> Orient polygon soup"
To produce a 3D mesh you can then do:
Save in back to an off file and reload it.
Then do:
"Operation -> Create a tetrahedral mesh"
or directly use your code.
I used JMeshLib (http://jmeshlib.sourceforge.net/) to reorient
all triangles, but the output surface mesh still crashed the
polyhedral mesher. The surface meshes before and after
the reorientation can be found here
http://nmr.mgh.harvard.edu/~fangq/temp/pre_cgalpoly.off
http://nmr.mgh.harvard.edu/~fangq/temp/pre_cgalpoly_reorder.off
any more comments?
thanks
Qianqian
If you copied-pasted an example, you should adapt the parameter
values of the criteria because those in the example are proper to the
hard-coded model (in particular size criteria).
The demo and the following worked for me:
#include <CGAL/Mesh_triangulation_3.h>
#include <CGAL/Mesh_complex_3_in_triangulation_3.h>
#include <CGAL/Mesh_criteria_3.h>
#include <CGAL/Polyhedral_mesh_domain_3.h>
#include <CGAL/make_mesh_3.h>
#include <CGAL/refine_mesh_3.h>
// IO
#include <CGAL/IO/Polyhedron_iostream.h>
// Domain
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Polyhedron_3<K> Polyhedron;
typedef CGAL::Polyhedral_mesh_domain_3<Polyhedron, K> Mesh_domain;
// Triangulation
typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr;
typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr> C3t3;
// Criteria
typedef CGAL::Mesh_criteria_3<Tr> Mesh_criteria;
// To avoid verbose function and named parameters call
using namespace CGAL::parameters;
int main()
// Create input polyhedron
Polyhedron polyhedron;
std::ifstream input("pre_cgalpoly_reorder.off");
input >> polyhedron;
// Create domain
Mesh_domain domain(polyhedron);
// Mesh criteria (no cell_size set)
Mesh_criteria criteria(facet_angle=25,
facet_size=3.5,
facet_distance=3.5,
cell_radius_edge=3);
// Mesh generation
C3t3 c3t3 =
CGAL::make_mesh_3<C3t3>(domain,criteria,no_perturb(),no_exude());
return 0;
- [cgal-discuss] Finite Element Analysis, Fabio Casado Ruiz, 03/17/2011
- Re: [cgal-discuss] Finite Element Analysis, Christoph Weber, 03/18/2011
- Re: [cgal-discuss] Finite Element Analysis, Sebastien Loriot (GeometryFactory), 03/18/2011
- Re: [cgal-discuss] Finite Element Analysis, Fabio Casado Ruiz, 03/19/2011
- Re: [cgal-discuss] Finite Element Analysis, Pedro Machado Manhães de Castro, 03/19/2011
- Re: [cgal-discuss] Finite Element Analysis, Daniel Duque, 03/20/2011
- Re: [cgal-discuss] Finite Element Analysis, Qianqian Fang, 03/21/2011
- Re: [cgal-discuss] Finite Element Analysis, Sebastien Loriot (GeometryFactory), 03/21/2011
- Re: [cgal-discuss] Finite Element Analysis, Laurent Rineau (GeometryFactory), 03/21/2011
