- To:
- Cc: "Laurent Rineau (GeometryFactory)" <>
- Subject: Re: [cgal-discuss] Finite Element Analysis
- Date: Mon, 21 Mar 2011 14:50:53 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:cc:subject :references:in-reply-to:content-type; b=OEx7acWHq9zrIpNJnFpmf/N2B0Wrr6BDqDjjrq19Ju7HyJSGdRMAaactPE5WvSPopb hnURAo2JIGfgnzNT84DZlXe1NTT37IM5d434Iutd+yeP5IX9It8HIXn9epW1DYeFKcQX bVCKEbuHjYSsW7vjbTAWReKM2a0kLhaemTsbs=
On 03/21/2011 01:56 PM, Laurent Rineau (GeometryFactory) wrote:
You were right, the reordered surface works fine with CGAL 3.8beta. My previous test was done with a binary compiled against CGAL 3.6.1.
the source code of the modified 3d mesher and polyhedral mesher are provided in a top-level folder as iso2mesh, here is the path: https://orbit.nmr.mgh.harvard.edu/plugins/scmsvn/viewcvs.php/trunk/cgalmesh/?root=iso2mesh inside the CGAL folder, I also have a few units modified for RNG seeding and other minor tweaks. I will regenerate all CGAL binaries for iso2mesh with 3.8beta. Thanks for the great works from the CGAL team for developing these powerful tools. Just go back to the CGAL vs tetgen comparison, does CGAL polyhedral domain mesher provides a way to seed (or label) a compartment (region) or a hole in the resulting tetrahedral mesh? see the format in tetgen http://tetgen.berlios.de/fformats.poly.html If my input surface have multiple partitions (a subregion of surface), can CGAL polyhedon mesher label and return the refined surfaces after the meshing with consistent partition IDs ? If these features are possible in CGAL, then I think it is probably a good time to set CGAL tools as default in iso2mesh, as tetgen is not strictly speaking open-source. Qianqian
- Re: [cgal-discuss] Finite Element Analysis, (continued)
- Re: [cgal-discuss] Finite Element Analysis, Sebastien Loriot (GeometryFactory), 03/18/2011
- Re: [cgal-discuss] Finite Element Analysis, Christoph Weber, 03/18/2011
- Re: [cgal-discuss] Finite Element Analysis, Fabio Casado Ruiz, 03/19/2011
- Re: [cgal-discuss] Finite Element Analysis, Pedro Machado Manhães de Castro, 03/19/2011
- Re: [cgal-discuss] Finite Element Analysis, Daniel Duque, 03/20/2011
- Re: [cgal-discuss] Finite Element Analysis, Qianqian Fang, 03/21/2011
- Re: [cgal-discuss] Finite Element Analysis, Sebastien Loriot (GeometryFactory), 03/21/2011
- Re: [cgal-discuss] Finite Element Analysis, Laurent Rineau (GeometryFactory), 03/21/2011
