- To:
- Subject: Re: [cgal-discuss] Finite Element Analysis
- Date: Sun, 20 Mar 2011 21:26:28 +0100
El 19/03/2011 7:44, Pedro Machado Manhães de Castro escribió:
You may want to know: http://www.cs.berkeley.edu/~jrs/stellar/ <http://www.cs.berkeley.edu/%7Ejrs/stellar/>
If your optimality criterion is big min dihedral angles, and small max dihedral angles of tetrahedra, then I think you wouldn't be disappointed with the reference above.
I knew of a fine article titled "What Is a Good Linear Finite Element?" I was going to recommend -- it turns out it's by the same jrs fellow!
It can be found here:
http://www.cs.cmu.edu/~jrs/jrspapers.html#quality <http://www.cs.cmu.edu/%7Ejrs/jrspapers.html#quality>
Best,
Daniel
- [cgal-discuss] Finite Element Analysis, Fabio Casado Ruiz, 03/17/2011
- Re: [cgal-discuss] Finite Element Analysis, Christoph Weber, 03/18/2011
- Re: [cgal-discuss] Finite Element Analysis, Sebastien Loriot (GeometryFactory), 03/18/2011
- Re: [cgal-discuss] Finite Element Analysis, Fabio Casado Ruiz, 03/19/2011
- Re: [cgal-discuss] Finite Element Analysis, Pedro Machado Manhães de Castro, 03/19/2011
- Re: [cgal-discuss] Finite Element Analysis, Daniel Duque, 03/20/2011
- Re: [cgal-discuss] Finite Element Analysis, Qianqian Fang, 03/21/2011
- Re: [cgal-discuss] Finite Element Analysis, Sebastien Loriot (GeometryFactory), 03/21/2011
- Re: [cgal-discuss] Finite Element Analysis, Laurent Rineau (GeometryFactory), 03/21/2011
