cgal-discuss - Re: [cgal-discuss] Alpha_shape_2 with info
  • To:
  • Subject: Re: [cgal-discuss] Alpha_shape_2 with info
  • Date: Thu, 19 May 2011 15:46:20 +0200
push_back should be private too.
If you use push_back,
the triangulation will be updated but not the alpha_shapes...
I don't see any problem in what you propose.
Le 19/05/11 12:46, Asher Kamiraze a écrit :
Hi all,
Is there a way to build an alpha_shape_2 with info? Something similar to a triangulation with info.
I have also noticed that insert() is private in alpha_shape_2, but, push_back is not. Isn't it a problem?
Here is what I am trying to do:
typedef CGAL::Exact_predicates_exact_constructions_kernel K;
struct vertex_info { Point point3d; };
struct face_info {};
typedef CGAL::Triangulation_vertex_base_with_info_2<vertex_info,K> Vb_2;
typedef CGAL::Constrained_triangulation_face_base_with_info_2<face_info,K> Fb_2;
typedef CGAL::Alpha_shape_vertex_base_2<K, Vb_2> Vb;
typedef CGAL::Alpha_shape_face_base_2<K, Fb_2> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb,Fb> TDS_2;
typedef CGAL::Delaunay_triangulation_2<K , TDS_2> DT_2;
typedef CGAL::Alpha_shape_2<DT_2> Alpha_shape_2;
Alpha_shape_2 alpha_shape(0.5);
// How to insert points in alpha_shape with attached info?
Hope you could help
Best regards
Asher
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
