- To:
- Subject: [cgal-discuss] Alpha_shape_2 with info
- Date: Thu, 19 May 2011 12:46:00 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=BBDba85fPH1Tq0zORVae8Ts4UPZamhMrqXTFWFyf2HP/Z1fOdYOgB/nmuBFDAX7upq QBkfGbmbQgM2lV2r+xoZlYS0iMGz0DXJZYpADSBoHRFV/YxFmFUXRhkH5pLkgVp4EYFB xo4vg1/PH0igmaNIJkC9bKmAeGE+EiK6d7tq0=
Hi all,
Is there a way to build an alpha_shape_2 with info? Something similar to a triangulation with info.
I have also noticed that insert() is private in alpha_shape_2, but, push_back is not. Isn't it a problem?
Here is what I am trying to do:
typedef CGAL::Exact_predicates_exact_constructions_kernel K;
struct vertex_info { Point point3d; };
struct face_info {};
typedef CGAL::Triangulation_vertex_base_with_info_2<vertex_info,K> Vb_2;
typedef CGAL::Constrained_triangulation_face_base_with_info_2<face_info,K> Fb_2;
typedef CGAL::Alpha_shape_vertex_base_2<K, Vb_2> Vb;
typedef CGAL::Alpha_shape_face_base_2<K, Fb_2> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb,Fb> TDS_2;
typedef CGAL::Delaunay_triangulation_2<K , TDS_2> DT_2;
typedef CGAL::Alpha_shape_2<DT_2> Alpha_shape_2;
Alpha_shape_2 alpha_shape(0.5);
// How to insert points in alpha_shape with attached info?
Hope you could help
Best regards
Asher
- [cgal-discuss] Alpha_shape_2 with info, Asher Kamiraze, 05/19/2011
- Re: [cgal-discuss] Alpha_shape_2 with info, Mariette Yvinec, 05/19/2011
- Re: [cgal-discuss] Alpha_shape_2 with info, Asher Kamiraze, 05/19/2011
- Re: [cgal-discuss] Alpha_shape_2 with info, Sebastien Loriot (GeometryFactory), 05/19/2011
- Re: [cgal-discuss] Alpha_shape_2 with info, Asher Kamiraze, 05/27/2011
- Re: [cgal-discuss] Alpha_shape_2 with info, Sebastien Loriot (GeometryFactory), 05/27/2011
