cgal-discuss - Re: [cgal-discuss] Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?
  • To:
  • Subject: Re: [cgal-discuss] Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?
  • Date: Mon, 27 Jun 2011 09:09:46 +0200
How did you check that the source and target of the segment
are equal?
If you checked it with an assertion in the code, then we probably need
to get a minimal example showing the problem to provide you a fix.
Sebastien.
randooom wrote:
tl;dr: see subject line
Following a little explanation what I try to accomplish and why.
I have a Regular_triangulation_3 rt and want to extract the power diagram
cell by cell (and only the finite ones).
My algorithm is basically as follows:
CellContainer cells
foreach finite_vertex fv in rt:
foreach incident_cell ic to fv:
check if ic is infinite.
if no_infinite_incident_cell_found
MyCell mc foreach incident_vertex iv of fv:
MyFacet mf
get edge e with rt.is_edge(fv, iv, ...)
circulate over incident_facets if of e:
Segment_3 s = (Object cast and so forth) rt.dual(if) // [1] mf.addEdge(s)
mc.addFacet(mf)
cells.addCell(mc)
[1] at this point I sometimes get a Segment_3 s with identical s.source()
and s.target(). How can this be, and what can I do about it? This makes
really no sense to me... :)
Thank you for you time reading this and I hope someone can help me; any tips
and suggestions are much appreciated!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Why-does-Regular-triangulation-3-dual-Facet-f-sometimes-return-a-edge-with-identical-source-and-targ-tp3625888p3625888.html
