Re: [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?
- To:
- Subject: Re: [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?
- Date: Mon, 27 Jun 2011 17:57:37 +0200
In 2 dimension the package Voronoi diagram,
more precisely 2D Voronoi Adaptor
allows to compute the power diagram
by filtering out, nul edges corresponding to
degenerate situations.
You could do something similar in 3D to get the Voronoi
diagram.
Le 27/06/11 16:38, randooom a écrit :
That is unfortunate, but thank you very much for the clarification.
How would I go on to implement a periodic boundary condition for the power
diagram?
Because that is what I tried to accomplish in the first place. (even if it
didn't look like so ;) )
I know that CGAL has a periodic delaunay triangulation, but I/we need the
power diagram so this doesn't really help.
Any tip is much appreciated.
Daniel
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Why-does-Regular-triangulation-3-dual-Facet-f-sometimes-return-a-edge-with-identical-source-and-targ-tp3625888p3627878.html
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
- [cgal-discuss] Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, randooom, 06/26/2011
- [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, randooom, 06/26/2011
- Re: [cgal-discuss] Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, Sebastien Loriot (GeometryFactory), 06/27/2011
- Re: [cgal-discuss] Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, Mariette Yvinec, 06/27/2011
- [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, randooom, 06/27/2011
- Re: [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, Sebastien Loriot (GeometryFactory), 06/27/2011
- Re: [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, Mariette Yvinec, 06/27/2011
- Re: [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, Monique Teillaud, 06/27/2011
