Re: [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?
- To:
- Subject: Re: [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?
- Date: Mon, 27 Jun 2011 16:40:54 +0200
In your example, all the weights are equal so the periodic Delaunay
would be enough. But I don't know if in the real life your weights are
different.
Sebastien.
randooom wrote:
That is unfortunate, but thank you very much for the clarification.
How would I go on to implement a periodic boundary condition for the power
diagram?
Because that is what I tried to accomplish in the first place. (even if it
didn't look like so ;) )
I know that CGAL has a periodic delaunay triangulation, but I/we need the
power diagram so this doesn't really help.
Any tip is much appreciated.
Daniel
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Why-does-Regular-triangulation-3-dual-Facet-f-sometimes-return-a-edge-with-identical-source-and-targ-tp3625888p3627878.html
- [cgal-discuss] Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, randooom, 06/26/2011
- [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, randooom, 06/26/2011
- Re: [cgal-discuss] Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, Sebastien Loriot (GeometryFactory), 06/27/2011
- Re: [cgal-discuss] Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, Mariette Yvinec, 06/27/2011
- [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, randooom, 06/27/2011
- Re: [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, Sebastien Loriot (GeometryFactory), 06/27/2011
- Re: [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, Mariette Yvinec, 06/27/2011
- Re: [cgal-discuss] Re: Why does Regular_triangulation_3::dual( Facet f) sometimes return a edge with identical source and target?, Monique Teillaud, 06/27/2011
