cgal-discuss - Re: [cgal-discuss] surface-parametrization
  • To:
  • Subject: Re: [cgal-discuss] surface-parametrization
  • Date: Thu, 7 Jul 2011 19:06:45 +0200
first i don't understand how i use 'Surface_mesh_parameterization example ' after i compile it with c-make  sorry but this is the first that i will use cgal
and i don't know how i can use the file .off to have the paramatrization method ?
2011/7/7 Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com>
amich randa wrote:
how can i run it with this option i can not do anything
I am sorry, I don't know what to add.
Please either try the demo or ask to your favorite
search engine how to run a program compiled with visual
in command-line mode on windows.
Sebastien.
2011/7/7 Sebastien Loriot (GeometryFactory) <sloriot.ml <http://sloriot.ml>@gmail.com <http://gmail.com>>
   This is a command-line program, you need to do run the exe with
   option -h
   You probably need to use the precompiled demo instead.
   download here the polyhedron demo that among other things
   do the surface mesh parametrization.
   http://www.cgal.org/demo/3.8/__polyhedron_3.zip
   <http://www.cgal.org/demo/3.8/polyhedron_3.zip>
   You need to extract these dll in the same directory than
   the demo
   http://www.cgal.org/demo/3.8/__CGAL-demoDLLs.zip
   <http://www.cgal.org/demo/3.8/CGAL-demoDLLs.zip>
   Sebastien.
   amich randa wrote:
       where can i find this help menu please ?
       <http://sloriot.ml> <http://sloriot.ml>@gmail.com
       <http://gmail.com> <http://gmail.com>>
          Here is the help menu:
          ./polyhedron_ex_____parameterization  --help
          PARAMETERIZATION
          Allowed options:
           -h [ --help ]                  prints this help message
           -t [ --type ] arg (=floater)   parameterization method: floater,
          conformal,
                                          barycentric, authalic or lscm
           -b [ --border ] arg (=circle)  border shape: circle, square
       or 2pts
          (lscm
                                          only)
           -s [ --solver ] arg (=opennl)  solver: opennl or taucs
           -i [ --input ] arg             input mesh (OFF)
           -o [ --output ] arg (=out.eps) output file (EPS or OBJ)
          amich randa wrote:
              sorry but i don't understand
       <http://sloriot.ml>
       <http://gmail.com>
                 amich randa wrote:
                     I am beginner with cgal;
                     I compiled the first example with c-make after I know
              what to do
                     to achieve this parameterization
                     and how if for example I use
                     'polyhedron_ex_______parameterization.cpp' I
       realize my
                     littleparameterization and where I can insert the
       inputfile
                 type ./polyhedron_ex_______parameterization -h for a
       detailed
              description of
                 the command line.
                 Sebastien.
                 --     You are currently subscribed to cgal-discuss.
                 https://lists-sop.inria.fr/______wws/info/cgal-discuss
       <https://lists-sop.inria.fr/____wws/info/cgal-discuss>
       <https://lists-sop.inria.fr/__wws/info/cgal-discuss>>
       <https://lists-sop.inria.fr/wws/info/cgal-discuss>>>
              --         */Randa Amich
              Élève ingénieur en 3eme année informatique
              École Nationale des Sciences de l'Informatique
              Master de  Recherche Informatique
              Tel:(+216) 20 67 04 71/*
              */Mail :
       <mailto:> <mailto:
       <mailto:>>
              <mailto:
       <mailto:> <mailto:
       <mailto:>>__>__/*
       --         */Randa Amich
       */Mail : <mailto:>
       <mailto: <mailto:>>__/*
*/Randa Amich
*/Mail : <mailto:>/*
Randa Amich
Mail :
