- To:
- Subject: Re: [cgal-discuss] surface-parametrization
- Date: Thu, 7 Jul 2011 22:23:13 +0100
You managed to compile the example using cmake? so you must have opened up a command prompt (i.e. start->run "cmd.exe") and then get a black window with:
Microsoft Windows [Version 6.1.7600]
Copyright (c) Microsoft Corporation. All rights reserved.
C:\
All Sebastien is telling you to do is at the C:\ type out C:\CGAL\polyhedron_ex_parameterization -h
so you just type " -h" at the end and it will print out some help text
Does that make things any clearer?
Regards
On 7 July 2011 18:06, amich randa <> wrote:
first i don't understand how i use 'Surface_mesh_parameterization example ' after i compile it with c-makesorry but this is the first that i will use cgal
and i don't know how i can use the file .off to have the paramatrization method ?
- Re: [cgal-discuss] surface-parametrization, (continued)
- Re: [cgal-discuss] surface-parametrization, Sebastien Loriot (GeometryFactory), 07/07/2011
- Re: [cgal-discuss] surface-parametrization, amich randa, 07/07/2011
- Re: [cgal-discuss] surface-parametrization, Giles Bathgate, 07/07/2011
- Re: [cgal-discuss] surface-parametrization, amich randa, 07/08/2011
