- To:
- Subject: Re: [cgal-discuss] Merging 2d triangles
- Date: Fri, 23 Dec 2011 19:00:47 -0500
Sorry, one more q: is it important to track either whether a result triangle is from an "overlap" and/or which source triangle (or triangle list) the triangle comes from)?
The more of this "meta data" you care about, the more complex the implementation I suspect...
On 12/23/11 6:49 PM, James wrote:
Hi,
I am trying to merge a list of 2d triangles that may or may not overlap into
a new list of triangles that no longer overlap.
E.g. two overlapping triangles T1 and T2 merge to create 8 new smaller
triangles
http://i.imgur.com/WvXaO.png
(ignore the colours)
I tried out the example Boolean_set_operations_2/sequence.cpp and then
modified it as it seemed to be what I want to do but my simple changes
resulted in an orientation error. I'm somewhat out of my depth here.
Can someone experienced with CGAL give me a small example of how this might
be achieved and what problems I might encounter. I suspect it should be a
simple problem.
thanks,
James
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Merging-2d-triangles-tp4230142p4230142.html
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://www.x-plane.com/blog/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] Merging 2d triangles, James, 12/24/2011
- Re: [cgal-discuss] Merging 2d triangles, Ben Supnik, 12/24/2011
- [cgal-discuss] Re: Merging 2d triangles, James, 12/24/2011
- Re: [cgal-discuss] Merging 2d triangles, James Swift, 12/24/2011
- Re: [cgal-discuss] Merging 2d triangles, Sebastien Loriot (GeometryFactory), 12/26/2011
