cgal-discuss - [cgal-discuss] Re: Merging 2d triangles
  • To:
  • Subject: [cgal-discuss] Re: Merging 2d triangles
  • Date: Fri, 23 Dec 2011 16:16:46 -0800 (PST)
Hi Ben,
The triangles overlap a lot
Imagine an array of 50 triangles initialised with random vertices
inside some bounding rectangle.
This of course means there could be all manner of gaps, overlap,
non-overlap, etc.
My goal is to turn that list of random triangles into triangle lists
that no longer overlap.
I hope that makes some sense.
Good performance would be nice but is not essential. First I'd just
like to understand the process and get something working :)
thanks,
James
On 24 December 2011 00:59, Ben Supnik [via cgal-discuss]
<[hidden email]> wrote:
> Hi James,
> A few q's:
> - For each incoming list, are you sure the triangles do not overlap?
> - Do the incoming triangle lists each cover an area completely, or are
> there gaps?
> - Is performance important?
> cheers
> Ben
> On 12/23/11 6:49 PM, James wrote:
>> Hi,
>> I am trying to merge a list of 2d triangles that may or may not overlap
>> into
>> a new list of triangles that no longer overlap.
>> E.g. two overlapping triangles T1 and T2 merge to create 8 new smaller
>> triangles
>> http://i.imgur.com/WvXaO.png
>> (ignore the colours)
>> I tried out the example Boolean_set_operations_2/sequence.cpp and then
>> modified it as it seemed to be what I want to do but my simple changes
>> resulted in an orientation error. I'm somewhat out of my depth here.
>> Can someone experienced with CGAL give me a small example of how this
>> might
>> be achieved and what problems I might encounter. I suspect it should be a
>> simple problem.
>> thanks,
>> James
>> View this message in context:
>> http://cgal-discuss.949826.n4.nabble.com/Merging-2d-triangles-tp4230142p4230142.html
>> Sent from the cgal-discuss mailing list archive at Nabble.com.
> Scenery Home Page: http://scenery.x-plane.com/
> Scenery blog: http://www.x-plane.com/blog/
> Plugin SDK: http://www.xsquawkbox.net/xpsdk/
> X-Plane Wiki: http://wiki.x-plane.com/
> Scenery mailing list: [hidden email]
> Developer mailing list: [hidden email]
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
> ________________________________
> If you reply to this email, your message will be added to the discussion
> below:
> http://cgal-discuss.949826.n4.nabble.com/Merging-2d-triangles-tp4230142p4230160.html
> To unsubscribe from Merging 2d triangles, click here.
> NAML
View this message in context: Re: Merging 2d triangles
