cgal-discuss - Re: [cgal-discuss] Merging 2d triangles
  • To:
  • Subject: Re: [cgal-discuss] Merging 2d triangles
  • Date: Mon, 26 Dec 2011 08:05:00 +0100
You can use a constrained Delaunay triangulation and allow edges to intersect. I think you'll get what you are looking for.
Sebastien.
James wrote:
Hi,
I am trying to merge a list of 2d triangles that may or may not overlap into
a new list of triangles that no longer overlap.
E.g. two overlapping triangles T1 and T2 merge to create 8 new smaller
triangles
http://i.imgur.com/WvXaO.png
(ignore the colours)
I tried out the example Boolean_set_operations_2/sequence.cpp and then
modified it as it seemed to be what I want to do but my simple changes
resulted in an orientation error. I'm somewhat out of my depth here.
Can someone experienced with CGAL give me a small example of how this might
be achieved and what problems I might encounter. I suspect it should be a
simple problem.
thanks,
James
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Merging-2d-triangles-tp4230142p4230142.html
