cgal-discuss - Re: [cgal-discuss] Merging 2d triangles
  • To:
  • Subject: Re: [cgal-discuss] Merging 2d triangles
  • Date: Sat, 24 Dec 2011 01:20:45 +0100
No meta data is really required after the merge, just a new list of triangles.
I suppose, optimally an opengl like triangle-list would be better than
each triangle described individually where vertices of shared edges
would be needlessly repeated.
On 24 December 2011 01:00, Ben Supnik
wrote:
> Sorry, one more q: is it important to track either whether a result triangle
> is from an "overlap" and/or which source triangle (or triangle list) the
> triangle comes from)?
> The more of this "meta data" you care about, the more complex the
> implementation I suspect...
> On 12/23/11 6:49 PM, James wrote:
>> Hi,
>> I am trying to merge a list of 2d triangles that may or may not overlap
>> into
>> a new list of triangles that no longer overlap.
>> E.g. two overlapping triangles T1 and T2 merge to create 8 new smaller
>> triangles
>> http://i.imgur.com/WvXaO.png
>> (ignore the colours)
>> I tried out the example Boolean_set_operations_2/sequence.cpp and then
>> modified it as it seemed to be what I want to do but my simple changes
>> resulted in an orientation error. I'm somewhat out of my depth here.
>> Can someone experienced with CGAL give me a small example of how this
>> might
>> be achieved and what problems I might encounter. I suspect it should be a
>> simple problem.
>> thanks,
>> James
>> View this message in context:
>> http://cgal-discuss.949826.n4.nabble.com/Merging-2d-triangles-tp4230142p4230142.html
>> Sent from the cgal-discuss mailing list archive at Nabble.com.
> Scenery Home Page: http://scenery.x-plane.com/
> Scenery blog: http://www.x-plane.com/blog/
> Plugin SDK: http://www.xsquawkbox.net/xpsdk/
> X-Plane Wiki: http://wiki.x-plane.com/
> Scenery mailing list:
> Developer mailing list:
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
