- To:
- Subject: [cgal-discuss] Re: Merging 2d triangles
- Date: Sat, 24 Dec 2011 02:16:36 -0800 (PST)
OK thanks Ben. I'll give it a shot and report back.
On Dec 24, 2011 1:33 AM, "Ben Supnik [via cgal-discuss]" <[hidden email]> wrote:
Hi James,
Hrm - well, it won't be fast but you I suppose you can do a "join" on a
huge list of triangles (turn each triangle into a polygon_2 and join
them into a general polygon set). Then use CGAL to re-triangulate the
resulting output polygons with holes.
If you were already trying this and got orientation errors you'll need
to hand-check your triangles - call orientation() on each triangle - if
it is clockwise, reverse its vertex order; if it is collinear you'll
need to throw it out - CGAL doesn't like degenerate geometry.
(This is in line with your current approach I think.)
It looks like others have discussed going from polygon-with-holes back
to triangulation.
http://stackoverflow.com/questions/406301/polygon-triangulation-with-holes#406647
Note that you'll need an exact constructions kernel, and you'll hit a
speed penalty for that.
cheers
Ben
On 12/23/11 7:20 PM, James Swift wrote:>>> Sent from the cgal-discuss mailing list archive at Nabble.com.
> No meta data is really required after the merge, just a new list of triangles.
> I suppose, optimally an opengl like triangle-list would be better than
> each triangle described individually where vertices of shared edges
> would be needlessly repeated.
> On 24 December 2011 01:00, Ben Supnik<[hidden email]> wrote:
>> Sorry, one more q: is it important to track either whether a result triangle
>> is from an "overlap" and/or which source triangle (or triangle list) the
>> triangle comes from)?
>> The more of this "meta data" you care about, the more complex the
>> implementation I suspect...
>> On 12/23/11 6:49 PM, James wrote:
>>> Hi,
>>> I am trying to merge a list of 2d triangles that may or may not overlap
>>> into
>>> a new list of triangles that no longer overlap.
>>> E.g. two overlapping triangles T1 and T2 merge to create 8 new smaller
>>> triangles
>>> http://i.imgur.com/WvXaO.png
>>> (ignore the colours)
>>> I tried out the example Boolean_set_operations_2/sequence.cpp and then
>>> modified it as it seemed to be what I want to do but my simple changes
>>> resulted in an orientation error. I'm somewhat out of my depth here.
>>> Can someone experienced with CGAL give me a small example of how this
>>> might
>>> be achieved and what problems I might encounter. I suspect it should be a
>>> simple problem.
>>> thanks,
>>> James
>>> View this message in context:
>>> http://cgal-discuss.949826.n4.nabble.com/Merging-2d-triangles-tp4230142p4230142.html
>> Scenery Home Page: http://scenery.x-plane.com/
>> Scenery blog: http://www.x-plane.com/blog/
>> Plugin SDK: http://www.xsquawkbox.net/xpsdk/
>> X-Plane Wiki: http://wiki.x-plane.com/
>> Scenery mailing list: [hidden email]
>> Developer mailing list: [hidden email]
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/wws/info/cgal-discuss
If you reply to this email, your message will be added to the discussion below:http://cgal-discuss.949826.n4.nabble.com/Merging-2d-triangles-tp4230142p4230206.html
View this message in context: Re: Merging 2d triangles
- [cgal-discuss] Merging 2d triangles, James, 12/24/2011
- Re: [cgal-discuss] Merging 2d triangles, Ben Supnik, 12/24/2011
- [cgal-discuss] Re: Merging 2d triangles, James, 12/24/2011
- Re: [cgal-discuss] Merging 2d triangles, James Swift, 12/24/2011
- Re: [cgal-discuss] Merging 2d triangles, Sebastien Loriot (GeometryFactory), 12/26/2011
