cgal-discuss - Re: [cgal-discuss] Static vs Shared
  • To:
  • Subject: Re: [cgal-discuss] Static vs Shared
  • Date: Wed, 25 Jul 2012 13:24:10 +0200
Le vendredi 20 juillet 2012 12:34:54 Panagiotis Foteinos a écrit :
> Hello.
> I built CGAL-4.0.2 with SHARED_LIBRARIES off.
What you said is not precise enough. Can you confirm that you set
BUILD_SHARED_LIBS to OFF during the configuration of CGAL libraries?
In /usr/local/lib/CGAL/CGALConfig.cmake, what is the value of the variable
CGAL_BUILD_SHARED_LIBS?
Laurent Rineau, PhD
