- To:
- Subject: Re: Re: [cgal-discuss] Static vs Shared
- Date: Thu, 26 Jul 2012 13:02:03 +0200
Le jeudi 26 juillet 2012 06:49:17 Panagiotis Foteinos a écrit :
> BUILD_SHARED_LIBS is set to OFF during the configuration.
> Variable CGAL_BUILD_SHARED_LIBS is also OFF inside CGALConfig.cmake
> I repeat that only .a libraries are generated, as it ought to be. My
> project, however, is searching for shared libraries.
> Anyhow, it seems that the problem appears only in RedHat, since in
> Ubuntu I had no problem.
It looks like a bug in CMake. Can you tell us which versions of CMake are
installed on the Ubuntu and RedHat distribution you use?
Laurent Rineau, PhD
- [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/20/2012
- Re: [cgal-discuss] Static vs Shared, Jakob van Bethlehem, 07/23/2012
- Re: [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/23/2012
- Re: [cgal-discuss] Static vs Shared, Sebastien Loriot (GeometryFactory), 07/25/2012
- Re: [cgal-discuss] Static vs Shared, Laurent Rineau (CGAL/GeometryFactory), 07/25/2012
- Re: [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/26/2012
- Re: Re: [cgal-discuss] Static vs Shared, Laurent Rineau (CGAL/GeometryFactory), 07/26/2012
- Re: Re: [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/26/2012
- Re: Re: Re: [cgal-discuss] Static vs Shared, Laurent Rineau (CGAL/GeometryFactory), 07/26/2012
- Re: Re: Re: Re: [cgal-discuss] Static vs Shared, Laurent Rineau (CGAL/GeometryFactory), 07/27/2012
- Re: Re: Re: Re: [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/27/2012
