cgal-discuss - Re: Re: Re: Re: [cgal-discuss] Static vs Shared
  • To:
  • Subject: Re: Re: Re: Re: [cgal-discuss] Static vs Shared
  • Date: Fri, 27 Jul 2012 12:00:45 -0400
Thank you for the fix,
Best,
Panagiotis
On Fri, Jul 27, 2012 at 8:50 AM, Laurent Rineau (CGAL/GeometryFactory)
wrote:
> Le jeudi 26 juillet 2012 18:54:33 Laurent Rineau a écrit :
>> Le jeudi 26 juillet 2012 12:47:17 Panagiotis Foteinos a écrit :
>> > It might worth mentioning that in the RedHat machine CGAL is actually
>> > "make installed", while in the ubuntu machine CGAL is merely "made".
>> I can reproduce the issue: if one build static CGAL libraries (.a files),
>> then the CGALConfig.cmake of the build tree shows .a files, but the
>> CGALConfig.cmake that is installed (the one in the config/ subdirectory of
>> the build tree) shows .so files. And the latter in incorrect for static
>> libraries. I do not think that has something to do with the precise CMake
>> version. That is probably a bug in CGAL CMake scripts. I will work on that
>> more tomorrow.
> I understand what happened. You almost certainly first launched cmake
> without BUILD_SHARED_LIBS=ON, and then you have modified the value of
> BUILD_SHARED_LIBS to OFF in the cache (maybe using cmake-gui), and
> relaunched the configuration. With that scenario, some variable values do
> not change when BUILD_SHARED_LIBS is toggled.
> Here is the patch, against CGAL-4.0.2/CMakeLists.txt:
> --- CMakeLists.txt (revision 70751)
> +++ CMakeLists.txt (working copy)
> @@ -669,10 +669,10 @@
> # Set CGAL_LIBRARY_NAME, CGAL_Qt3_LIBRARY_NAME and so on. Those variables
> # are the name of CGAL libraries, without the path. Used in the generation
> # of the installed CGALConfig.cmake
> -get_filename_component(CGAL_LIBRARY_NAME "${CGAL_LIBRARY}" NAME CACHE)
> +get_filename_component(CGAL_LIBRARY_NAME "${CGAL_LIBRARY}" NAME)
> hide_variable(CGAL_LIBRARY_NAME)
> foreach(lib ${CGAL_CONFIGURED_LIBRARIES})
> - get_filename_component(CGAL_${lib}_LIBRARY_NAME "${CGAL_${lib}_LIBRARY}"
> NAME CACHE)
> + get_filename_component(CGAL_${lib}_LIBRARY_NAME "${CGAL_${lib}_LIBRARY}"
> NAME)
> hide_variable(CGAL_${lib}_LIBRARY_NAME)
> endforeach()
> That is remove "CACHE" from the parameters of the two calls to
> get_filename_component().
> That patch will be included in the next release CGAL-4.1.
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
