- To:
- Subject: Re: Re: [cgal-discuss] Static vs Shared
- Date: Thu, 26 Jul 2012 07:26:05 -0400
Sure.
For Ubuntu: cmake version 2.8.8
For RedHat: cmake version 2.8.4
On Thu, Jul 26, 2012 at 7:02 AM, Laurent Rineau (CGAL/GeometryFactory)
wrote:
> Le jeudi 26 juillet 2012 06:49:17 Panagiotis Foteinos a écrit :
>> BUILD_SHARED_LIBS is set to OFF during the configuration.
>> Variable CGAL_BUILD_SHARED_LIBS is also OFF inside CGALConfig.cmake
>> I repeat that only .a libraries are generated, as it ought to be. My
>> project, however, is searching for shared libraries.
>> Anyhow, it seems that the problem appears only in RedHat, since in
>> Ubuntu I had no problem.
> It looks like a bug in CMake. Can you tell us which versions of CMake are
> installed on the Ubuntu and RedHat distribution you use?
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/20/2012
- Re: [cgal-discuss] Static vs Shared, Jakob van Bethlehem, 07/23/2012
- Re: [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/23/2012
- Re: [cgal-discuss] Static vs Shared, Sebastien Loriot (GeometryFactory), 07/25/2012
- Re: [cgal-discuss] Static vs Shared, Laurent Rineau (CGAL/GeometryFactory), 07/25/2012
- Re: [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/26/2012
- Re: Re: [cgal-discuss] Static vs Shared, Laurent Rineau (CGAL/GeometryFactory), 07/26/2012
- Re: Re: [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/26/2012
- Re: Re: Re: [cgal-discuss] Static vs Shared, Laurent Rineau (CGAL/GeometryFactory), 07/26/2012
- Re: Re: Re: Re: [cgal-discuss] Static vs Shared, Laurent Rineau (CGAL/GeometryFactory), 07/27/2012
- Re: Re: Re: Re: [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/27/2012
