- To:
- Subject: [cgal-discuss] Re[8]: Triangulation optimization around special points
- Date: Mon, 11 Mar 2013 06:18:43 -0700 (PDT)
I'll try it. Thank you!
Oleg
Monday, March 11, 2013, 19:39, you wrote:
> I repeat my answer: Use exact arithmetic to compute the intersection
> of the polyhedra, that way there is no notion of "almost intersecting"
> to handle.
> Use for example
> CGAL::Simple_cartesian<CGAL::Lazy_exact_nt<CGAL::Gmpq> >
> which is rather fast and exact and this package [1] to then compute the
> intersection of polyline segments. Once done you can switch everything
> back to double.
> Sebastien.
> [1]
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/AABB_tree/Chapter_main.html
> On 03/11/2013 01:17 PM, Oleg wrote:
>> Hello Sebastien! Thank you for the reference. I may use it in the
>> future, but for now I already can compute intersection of polyhedrons,
>> and my problem consists rather in the following. When I compute
>> intersections of a few polyhedrons, the mesh becomes essentially
>> non-uniform (crowded) around the points, where the intersecting
>> polylines intersect between themselves, like the one in the first
>> message:
>> <http://cgal-discuss.949826.n4.nabble.com/file/n4656843/3balls.gif> .
>> Laurent suggested that splitting the intersecting polylines at the
>> points, where they intersect between themselves, thus turning them
>> into "corner points" can help. Now I'm wondering what would be the
>> best way to achieve that..
>> Oleg
>> Monday, March 11, 2013, 13:10, you wrote:
>> > Since snap rounding in 3D is not easy, I think you should compute the
>> > intersecting polyline using exact arithmetic and then simplify the
>> output.
>> > For the computation of intersecting polylines, you might want to
>> > have a look at the non-documented function in
>> > CGAL/intersection_of_Polyhedra_3.h
>> > template <typename Polyhedron, typename OutputIterator>
>> > OutputIterator
>> > intersection_Polyhedron_3_Polyhedron_3(const Polyhedron& P, const
>> > Polyhedron& Q, OutputIterator out)
>> > where out expects object of type std::vector<typename Kernel::Point_3>
>> > representing a polyline
>> > Sebastien.
>> > On 03/07/2013 11:47 AM, Oleg wrote:
>> >> Yes, more general shapes. The final goal is to make uniform meshes for
>> >> bodies composed of general shapes with sharp boundaries between them.
>> >> Oleg
>> >> Thursday, March 7, 2013, 17:23, you wrote:
>> >> > What is the final goal? Only mesh 3 spheres? mesh n spheres? or more
>> >> > general shapes?
>> >> > I ask the question because the answer then varies.
>> >> > Sebastien.
>> >> > On 03/07/2013 11:16 AM, Oleg wrote:
>> >> >> Thursday, March 7, 2013, 16:53, you wrote:
>> >> >> > Le jeudi 07 mars 2013 00:00:11 Oleg a écrit :
>> >> >> >> Hello everyone! I have a question regarding triangulation
>> >> >> optimization. I
>> >> >> >> make a mesh for 3 balls intersection with 3 1D features. The
>> mesh is
>> >> >> uniform
>> >> >> >> everywhere except 2 points where the 3 boundaries intersect:
>> >> >> >> These points don't seem to represent any problem for a manual
>> >> meshing,
>> >> >> >> because the boundaries intersect at large angles. Is there any
>> easy
>> >> >> way to
>> >> >> >> optimize the mesh around these points to avoid the unnecessary
>> >> >> crowding? Any
>> >> >> >> ideas will be greatly appreciated.
>> >> >> > In your example, I assume that you have computed the
>> intersections of
>> >> >> spheres
>> >> >> > and set them as 1D features of the domain. When 1D-features
>> >> >> intersect, you
>> >> >> > need to split them first at the intersection points. That will
>> >> make the
>> >> >> > special intersections points as "corner points" of the domain, and
>> >> >> fix the
>> >> >> > crowding you see in the result.
>> >> >> You're right, that's what I did. I'll try what you recommend,
>> thanks!
>> >> >> Just another quick question - what would be the best way to find
>> >> >> intersection points of two polylines? Keeping in mind that the
>> >> >> polylines may not intersect in one exact point but rather pass by
>> >> >> each other at a small distance..?
>> >> >> Oleg
>> >> >> View this message in context: Re[2]: Triangulation optimization
>> around
>> >> >> special points
>> <http://cgal-discuss.949826.n4.nabble.com/Triangulation-optimization-around-special-points-tp4656843p4656846.html>
>> >> >> Sent from the cgal-discuss mailing list archive
>> >> >> <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
>> >> View this message in context: Re[4]: Triangulation optimization around
>> >> special points
>> <http://cgal-discuss.949826.n4.nabble.com/Triangulation-optimization-around-special-points-tp4656843p4656848.html>
>> View this message in context: Re[6]: Triangulation optimization around
>> special points
>> <http://cgal-discuss.949826.n4.nabble.com/Triangulation-optimization-around-special-points-tp4656843p4656892.html>
View this message in context: Re[8]: Triangulation optimization around special points
- [cgal-discuss] Triangulation optimization around special points, Oleg, 03/07/2013
- Re: [cgal-discuss] Triangulation optimization around special points, Laurent Rineau (CGAL/GeometryFactory), 03/07/2013
- [cgal-discuss] Re[2]: Triangulation optimization around special points, Oleg, 03/07/2013
- Re: [cgal-discuss] Re[2]: Triangulation optimization around special points, Sebastien Loriot (GeometryFactory), 03/07/2013
- [cgal-discuss] Re[4]: Triangulation optimization around special points, Oleg, 03/07/2013
- Re: [cgal-discuss] Re[4]: Triangulation optimization around special points, Sebastien Loriot (GeometryFactory), 03/11/2013
- [cgal-discuss] Re[6]: Triangulation optimization around special points, Oleg, 03/11/2013
- Re: [cgal-discuss] Re[6]: Triangulation optimization around special points, Sebastien Loriot (GeometryFactory), 03/11/2013
- [cgal-discuss] Re[8]: Triangulation optimization around special points, Oleg, 03/11/2013
