- To:
- Subject: Re: [cgal-discuss] Delaunay complex
- Date: Tue, 19 Mar 2013 09:50:48 +0100
Hi,
The symbolic perturbation is coded in Delaunay_triangulation_3.h, in class Perturbation_order. The side_of_sphere predicate uses this perturbation, so that it never returns 0.
Your question is interesting, but I don't see an easy way to mark tetrahedra on the fly, knowing the way the algorithm is coded...
As Laurent suggested, you can iterate on facets after the triangulation is constructed, call the non-perturbed predicate on their incident cells, and mark facets of tetrahedra that lie inside the polyhedral regions (using CGAL::Triangulation_cell_base_with_info_3).
Best,
Monique Teillaud
Le 19/03/13 09:07, Philipp Blanke a écrit :
Hello!
I'd like to construct a Delaunay complex for a point set that contains
several degenerate cases, i. e., >4 cospherical points. The doc says
that the Delaunay_triangulation_3 code solves the local disambiguity by
using a perturbation scheme.
If the tetrahedra that were constructed using this scheme would be
marked, I could merge them in a preprocessing step to get a Delaunay
complex consisting of convex polyhedra.
Where in the code is the perturbation scheme used to select a possible
tetrahedrization? I did not find this.
Best regards,
Philipp
Monique Teillaud
http://www.inria.fr/sophia/members/Monique.Teillaud/
INRIA Sophia Antipolis - Méditerranée
Institut National de Recherche en Informatique et Automatique
- [cgal-discuss] Delaunay complex, Philipp Blanke, 03/19/2013
- Re: [cgal-discuss] Delaunay complex, Sebastien Loriot (GeometryFactory), 03/19/2013
- Re: [cgal-discuss] Delaunay complex, Philipp Blanke, 03/19/2013
- Re: [cgal-discuss] Delaunay complex, Monique Teillaud, 03/19/2013
