- To: cgal-discuss <>
- Subject: Re: [cgal-discuss] Delaunay complex
- Date: Tue, 19 Mar 2013 13:45:08 +0100
Hello Monique & Sebastien ,
as I understand the incremental algorithm, if a tetrahedron T is marked degenerated and a point would be inserted into its circumsphere, T would be destroyed and the hole re-triangulated. The newly constructed tets would not automatically inherit the "degenerate" flag from T.Best regards!
Philipp
On Tue, Mar 19, 2013 at 9:34 AM, Sebastien Loriot (GeometryFactory) <> wrote:
I think if you proceed like this, since the algorithm is incremental, you can end up with tetrahedra marked that are no longer degenerated.
I think the method Laurent proposed you is the best.
Sebastien.--
On 03/19/2013 09:07 AM, Philipp Blanke wrote:
Hello!
I'd like to construct a Delaunay complex for a point set that contains
several degenerate cases, i. e., >4 cospherical points. The doc says
that the Delaunay_triangulation_3 code solves the local disambiguity by
using a perturbation scheme.
If the tetrahedra that were constructed using this scheme would be
marked, I could merge them in a preprocessing step to get a Delaunay
complex consisting of convex polyhedra.
Where in the code is the perturbation scheme used to select a possible
tetrahedrization? I did not find this.
Best regards,
Philipp
- [cgal-discuss] Delaunay complex, Philipp Blanke, 03/19/2013
- Re: [cgal-discuss] Delaunay complex, Sebastien Loriot (GeometryFactory), 03/19/2013
- Re: [cgal-discuss] Delaunay complex, Philipp Blanke, 03/19/2013
- Re: [cgal-discuss] Delaunay complex, Monique Teillaud, 03/19/2013
