cgal-discuss - Re: [cgal-discuss] Delaunay complex
  • To:
  • Subject: Re: [cgal-discuss] Delaunay complex
  • Date: Tue, 19 Mar 2013 14:44:55 +0100
Le 19/03/13 13:45, Philipp Blanke a écrit :
Hello Monique & Sebastien ,
as I understand the incremental algorithm, if a tetrahedron T is marked
degenerated and a point would be inserted into its circumsphere, T would
be destroyed and the hole re-triangulated. The newly constructed tets
would not automatically inherit the "degenerate" flag from T.
You suggest that a marked tetrahedron could lose its degenerate status,
since there could be an insertion of a point, so that there are not >4
points cospherical anymore. But such a point would have to be inserted
inside T's circumsphere.
I am not sure what Sébastien was referring to.
But at least if you remove all points that were cospherical with T's vertices, then T becomes non-degenerate.
Actually my point is not related with this. I just don't see how to easily
- 'catch' cospherical cases, since this is hidden in the (perturbed) predicate, which never returns 0
- and pass the information to the TDS, which is actually creating tetrahedra.
At first sight, I would say that, assuming it is possible, it would require a non-trivial patching of the CGAL code.
Was there an email from Laurent regarding this topic on the list?!
Laurent answered the email that you sent last week, with subject: Fwd: Delaunay_triangulation_3 degenerate case
best,
Monique
I did
not find one. But Monique's email has pointed me into the right
direction. Thank you!
Best regards!
Philipp
On Tue, Mar 19, 2013 at 9:34 AM, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
I think if you proceed like this, since the algorithm is
incremental, you can end up with tetrahedra marked that are no
longer degenerated.
I think the method Laurent proposed you is the best.
Sebastien.
On 03/19/2013 09:07 AM, Philipp Blanke wrote:
Hello!
I'd like to construct a Delaunay complex for a point set that
contains
several degenerate cases, i. e., >4 cospherical points. The doc says
that the Delaunay_triangulation_3 code solves the local
disambiguity by
using a perturbation scheme.
If the tetrahedra that were constructed using this scheme would be
marked, I could merge them in a preprocessing step to get a Delaunay
complex consisting of convex polyhedra.
Where in the code is the perturbation scheme used to select a
possible
tetrahedrization? I did not find this.
Best regards,
Philipp
https://sympa.inria.fr/sympa/__info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
Monique Teillaud
http://www.inria.fr/sophia/members/Monique.Teillaud/
INRIA Sophia Antipolis - Méditerranée
Institut National de Recherche en Informatique et Automatique
