cgal-discuss - Re: [cgal-discuss] Delaunay complex
  • To:
  • Subject: Re: [cgal-discuss] Delaunay complex
  • Date: Tue, 19 Mar 2013 13:58:30 +0100
On 03/19/2013 01:45 PM, Philipp Blanke wrote:
Hello Monique & Sebastien ,
as I understand the incremental algorithm, if a tetrahedron T is marked
degenerated and a point would be inserted into its circumsphere, T would
be destroyed and the hole re-triangulated. The newly constructed tets
would not automatically inherit the "degenerate" flag from T.
You suggest that a marked tetrahedron could lose its degenerate status,
since there could be an insertion of a point, so that there are not >4
points cospherical anymore. But such a point would have to be inserted
inside T's circumsphere.
Was there an email from Laurent regarding this topic on the list?! I did
not find one. But Monique's email has pointed me into the right
direction. Thank you!
See https://sympa.inria.fr/sympa/arc/cgal-discuss/2013-03/msg00138.html
Best regards!
Philipp
On Tue, Mar 19, 2013 at 9:34 AM, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
I think if you proceed like this, since the algorithm is
incremental, you can end up with tetrahedra marked that are no
longer degenerated.
I think the method Laurent proposed you is the best.
Sebastien.
On 03/19/2013 09:07 AM, Philipp Blanke wrote:
Hello!
I'd like to construct a Delaunay complex for a point set that
contains
several degenerate cases, i. e., >4 cospherical points. The doc says
that the Delaunay_triangulation_3 code solves the local
disambiguity by
using a perturbation scheme.
If the tetrahedra that were constructed using this scheme would be
marked, I could merge them in a preprocessing step to get a Delaunay
complex consisting of convex polyhedra.
Where in the code is the perturbation scheme used to select a
possible
tetrahedrization? I did not find this.
Best regards,
Philipp
https://sympa.inria.fr/sympa/__info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
