- To:
- Subject: [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails.
- Date: Mon, 13 May 2013 11:12:16 -0700 (PDT)
Philipp,
Thank you for the response.
Are you saying that you can produce the correct results on a 64-bit system
using the Simple_cartesian kernel? Because I have another system (64-bit
linux) with 64-bit boost, CGAL, etc. and was not able to obtain the correct
results using the Simple_cartesian kernel.
Using the "Exact_predicates_exact_constructions_kernel" does fix the
problem.
Willie B. Maddox Ph.D.
Physicist / Senior Systems Modeler
Science Applications International Corporation
Huntsville, AL USA
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/triangle-query-to-AABB-triangle-tree-returns-incorrect-intersection-objects-tp4657400p4657416.html
- [cgal-discuss] triangle_query to AABB_triangle_tree fails., placebo, 05/09/2013
- [cgal-discuss] Re: triangle_query to AABB_triangle_tree returns incorrect intersection objects, placebo, 05/09/2013
- Re: [cgal-discuss] triangle_query to AABB_triangle_tree fails., Philipp Moeller, 05/10/2013
- [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., placebo, 05/13/2013
- Re: [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., Sebastien Loriot (GeometryFactory), 05/14/2013
- [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., placebo, 05/14/2013
- Re: [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., Sebastien Loriot (GeometryFactory), 05/15/2013
- [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., ChaoM, 05/14/2013
