cgal-discuss - [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails.
  • To:
  • Subject: [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails.
  • Date: Tue, 14 May 2013 09:27:54 -0700 (PDT)
Sebastien,
Do I need to construct the point?
In the example above, the points are the first thing I "construct". The
triangles are constructed from those points and the tree is constructed from
the triangles. My query triangle is also constructed from the points. So,
should not the points already be constructed? I do not see why to
reconstruct them.
Thanks.
Willie B. Maddox Ph.D.
Physicist / Senior Systems Modeler
Science Applications International Corporation
Huntsville, AL USA
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/triangle-query-to-AABB-triangle-tree-returns-incorrect-intersection-objects-tp4657400p4657430.html
